Mobile Air Conditioning service
Re: Mobile Air Conditioning service
I just had Leigh come up to the OC and take care of my 1986 Bronco's AC and my son's 1994 Explorer's AC and we couldn't be happier. Leigh, you have a customer for life. Thank you!
mobil1syn
Post by mobil1syn »
so the 3 nubbins where on fire when i popped the hood. HELP!! drop me a text or give me a call. i am near the 60/215 split
mobil1syn
Post by mobil1syn »
951-675-8224
Whiterhino1
Bronco Info: 1994 bronco 4 inch lift 35's
Post by Whiterhino1 »
z
So here's a job I did recently, this allows you to run coilover and bypass with factory AC unit on 37s. All the lines are custom and the systmem works fantastic. This is a cost effective way to increase space for shocks. There will be a 3.0 bypass mounted behind the coilover
JamesGrossaint
Bronco Info: 1996 Ford Bronco
Post by JamesGrossaint »
Leighlan,
Can you message me you rates? Just got a 96 bronco that blows warm air and I have no clue where to start.
Whiterhino1
Hey James, my rates are 75 an hour, 75 call out fee is waived if you have me do the repairs. I have a shop in San Marcos if you want to bring it to me
What size is the fitting on the drivers side of the radiator/condenser area that's right in front sorta of the compressor? I need a fitting for that that has a 90* fitting-- a place called Gotta Show out of Phoenix makes (or sells one for a -8) and hope that will work.
