Garage clean up, things for sale
- Cactus Cooler
1. I have 3 complete sets of spring hangers 4 sale. These are stock hangers, but have chromoly washers welded on the in/outer areas of where the shackles bolt to. $50.00 a set 2 frnt, 2 rear
2. Still Have 4 Hella Lights w/ Rack $250.
3. Kenwood UHf radio $50.
4. BB Chevy 730 HP best of everything. To build was $18k +, professionally built, low low hours, included dyno sheet. stored properly and covered in garage. Built for my boat or make a bad ass street or off road deal. Open to reasonable offers.
- Cactus Cooler
Re: Garage clean up, things for sale
Also selling my 01 YZ 426 great desert bike, dez tank, acerbis hand guards, Kickstand, Rock Guard, NEW Renthal chain, sprocket & handle bars (2sets), newr Maxxis dez tires, heavy dez tubes, Radiator Guards, oil changed every ride, just had the carb re built this season, also has SCOTTS steering stabilizer bracket ( keeping stabilizer for new bike or will sell for additional $ 250.00) Whte bros. Pipe asking $1800. obo
- Cactus Cooler
Also possible trades for BRONCO SHTUFFFFFFF!
1996sleeper
- Bronco Info: 1996 2wd f150 autofab beams, coilovers, all terrains on alcoas and 351
Are the hangers for 2.5 wide spring or 3" wide springs
That engine is gorgeous. What are those tubes going to the headers?
- Cactus Cooler
sorry forgot to add that, they are 3"1996sleeper wrote:Are the hangers for 2.5 wide spring or 3" wide springs
- Cactus Cooler
The headers are water injected to keep them cool and from discoloring the headers. I had added to set of lines, 1 was for the injection( its just a fine mist )the other is so that they drain. I added the second set to drain back into the bilge area of the boat so that it didn't make a huge mess all over the aluminum and chrome.Tchajagos wrote:That engine is gorgeous. What are those tubes going to the headers?
- Cactus Cooler
And thank you, I did enjoy it. just wish I lived a little closer to the River when I had the boat.
1996sleeper
can you shoot me a text 619-607-6909
- Cactus Cooler
is the radio race programmed and does it have a mic?
- Cactus Cooler
No & maybe. To be clear this unit is usually used for short coarse racing not desert racing, It was in a wrecked city service truck at a wrecking yard. As I was looking for parts for the Bronco I discovered this and then realized once home it was UHF not VHF. but I grabbed it for a extra mic and antenna. And yes it does work just needs programming.
- Cactus Cooler
Sale pending on the lights.
- Cactus Cooler
Re:
good to know thanksWrightracing.net wrote:Fyi, UHF antenna will not work on a VHF race radio. It will make the radio perform poorly and burn out the finals on the radio over time.
- Cactus Cooler
