How do you properly measure ride height, and what are the stock measurement's vs what they should be with a 4" lift? I am needing to set my front ride height on a 84 Bronco with Fox 2.5" coilers mounted in a Solo coiler conversions and the current measurements are as follows:
Bottom of the frame near the body mount driver side: 23.5" vs. passenger side: 23.25"
Door roof seam on driver side: 76.5" vs. passenger side: 76"
It looks as if it set to low but I am suppressed I would need toolbar the coil spring adjuster's by that much?
Thanks, Richard
Stock ride height vs. 4" lift
Re: Stock ride height vs. 4" lift
Those measurements are erroneous due to tire size.
Measure top of beam to bottom of frame up front and top of axle to bottom of frame in rear. Jump under a stock bronco in a parking lot somewhere and compare. I would be curious to know what those dims are on a stock bronco as well.
rameen
- Bronco Info: 84 Bronco, 351W, C6, 9", 17x315 KO BFG's, also 75 Bronco, 302, C4, Dana44, 9", 15x33 KO BFG's
Updated Measurements: Driver side Passenger side
top of beam to bottom frame 6.5" 6.0"
top rear axle to bottom frame 10.75" 10.5"
still looking for a stock Bronco to measure... thanks in advance for advice.
