95 F150 - Project Marilyn
- Andy Jones
- Bronco Info: In the Works!
Have you tried SDHQ.? For alignment.
- Bronco Info: 06 F150 FX4 reg cab
Re: 95 F150 - Project Marilyn
I saw this truck at SDHQ on Saturday. Beautiful truck! Did you get the alignment handled?
Thanks man- it’s a pretty cool truck but it’s just been a tough build toward the end. Just for the record though SDHQ is not who did the alignment.
Getting dialed in!
- 278F0656-1058-4225-A314-4D35926E966C.jpeg (132.19 KiB) Viewed 2278 times
- funinthesun95
this has been a great build.
Thanks - I notice you’re running the usshift— I’m hoping I can get it dialed like I want. Can you adjust it to downshift with less pedal input? I don’t like pushing the OD button on my 96 Bronco for a boost of speed.
Haven’t posted on my F150 for sometime—I’ve been busy converting my 1995 over to a 96 OBDII - which has been loads of work!
Said in Bevis voice— BUNGHOLE!!
- C49780CC-8FA2-45CA-976F-4B4623D5CA47.jpeg (167.85 KiB) Viewed 2067 times
What’s the consensus on “Start” buttons?
- sydude
I personally dig ‘em, mostly because I HATE keys. I’m working on a completely keyless entry / ignition system for my truck that uses no keys/remotes at all.VintageIronFab wrote:What’s the consensus on “Start” buttons?
And I LOVE what you’re doing with Marilyn!
Thanks man I appreciate it!
This to me is the most OEM version I’ve seen ....
http://www.subispeed.com/2015-subaru-wr ... xLWOhZlDYU
- funinthesun95
I love this truck
This isn’t cheap but seems like O sooo good of an idea!!!
- 68B85647-B040-4D05-B5D1-CB8A55A5D1CC.jpeg (78.21 KiB) Viewed 1953 times
- sydude
It’s down to $5,995, I just looked. Pretty damn good for the money! But if you’re going to go through all the effort and expense of upgrading the engine, don’t skimp on the motor. I made that mistake myself by buying another 302 size motor after my original 302 blew, and ever since I’ve had my eyes on the Ford Racing Boss 351-based 427/460 crate engines. The 460 is the cheapest of the two I like (just under $10k) and the aluminum 427 is the pricey one at $14k or so. I’ll pull the trigger one day on one of these guys.VintageIronFab wrote:This isn’t cheap but seems like O sooo good of an idea!!!
Well when a nicely used Raptor have dropped to $26k a $14k engine seems like nonsense but that’s just me. The 408 is still a 351 based engine-$7500 delivered is about my max max MAX otherwise the cost seems like nonsense. There’s going to come a point where a 2013 F150 4x4 with a 5.0 in a Platinum trim with some miles is cheaper to put beams and supercharger on than a 1995 with a all the doodads. At that point a 1995 won be cool because well a 2013 starts with 360hp if I recall right and the 2013 frame is nicer and the interior is already killer ... and ... and ... and
There is a point where I’ve taken this truck where it’s the point of very diminishing returns.... man I’m a serious buzzkill!!
- sydude
Not at all! You're being very practical in a situation that's unemotional. It's not quite the same for me.. I've had my truck since it was brand new, and I have huge history with it, so it and are tied together in a very personal way. There's no getting rid of it, or choosing between it and another truck. It's all about treating this truck as well as I can, regardless of whatever else I have. And I barely drive her..VintageIronFab wrote:There is a point where I’ve taken this truck where it’s the point of very diminishing returns.... man I’m a serious buzzkill!!
Yeah but there’s fewer and fewer clean OBS F-series worth mentioning outside of this forum.... buuuttt a newer F150 with beams would be badass haha
Potato.
Where are you seeing Raptors for $26k ? ? lolVintageIronFab wrote:Well when a nicely used Raptor have dropped to $26k a $14k engine seems like nonsense but that’s just me. The 408 is still a 351 based engine-$7500 delivered is about my max max MAX otherwise the cost seems like nonsense. There’s going to come a point where a 2013 F150 4x4 with a 5.0 in a Platinum trim with some miles is cheaper to put beams and supercharger on than a 1995 with a all the doodads. At that point a 1995 won be cool because well a 2013 starts with 360hp if I recall right and the 2013 frame is nicer and the interior is already killer ... and ... and ... and
