- 7c4daf05e39a2c304b672a9b714b7e1b[1].jpg (24.4 KiB) Viewed 1164 times
Bray's 96 Sleeper
- De$ertBronco
Re: Bray's 96 Sleeper
JK! looks great brother!
haha, you aint lyin Josh! She is a glutton for attention, parts, gas and dollars!De$ertBronco wrote:JK! looks great brother!
HUGE thanks to the guys at Richer- especially Mike, who along with Eddie at Crown Performance, helped to figure out the puzzle of fittings and lines I needed to get the braking system right.
Big shout out to Josh for all of his expertise in all things Ford too- thank you for ALL the help brother.
Here's a shot of Mike's badass work (does not do it justice)
Battery in place, new rotors drilled out for 5/8" studs, fresh pads, seals and bearings.....
getting closer!
getting closer!
Steering in place.....
- Andy Jones
- Bronco Info: In the Works!
Bray's 96 Sleeper
What size are those fittings, on the side of the master cylinder?
Hey Andy, I will find out and get back to you when I talk with Mike....
Things are getting closer to completion...
- Andy Jones
Bray's 96 Sleeper
[quote="DMbronco"]Hey Andy, I will find out and get back to you when I talk with Mike....
Thanks man !
Thanks man !
Taylor snuck a shot this AM and sent my way.
First shot of the new stance (2" wider per side).
Stoked.
Stoked.
Bray's 96 Sleeper
That is perfect!
- apache41
- Bronco Info: 1995 Ford Bronco Solo Coilover front, Deaver Rear with Solo under bed shock bracket and hanger relo
Wow, very nice. I love the new King shocks. What spring rate are you going to run ?
Just like your wiring job Darren!!!! Hopefully I can get it as tidy as you left it the first time hahabirdco85 wrote:That is perfect!
Thanks Apache- here is the build sheet for the shocks- we'll see how they feel pretty soonapache41 wrote:Wow, very nice. I love the new King shocks. What spring rate are you going to run ?
Looking good, I saw the tin work a few pages back and did not see any venting near the headers or in the top. Are you concerned that all that sheet metal will hold in all that heat we get under the hood? I have seen guys with paint peeling in the metal hood and browning of the underside of fiberglass.
Love the Bronco.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Love the Bronco.
