I dont know yet I found some info on desertrangers and they said 5.5 inches on each side so, so maybe cut and turn but not extend them. Yea we will definitely half to make the new mounting brackets .Hauls Assington wrote:NIce! are you guys going to do a cut and turn on those beams?
I have read a little about it, and I believe there is a thread on here somewhere, and pretty much all you do is extend the lower balljoint location about 3/4". You will need to clearance the passenger side axle joint to get the most travel you can. Do you have any idea how much wider the d44 beams are compared to what was on the ranger?
Smith Racing 1450 TTB Ranger
Re: Smith Racing 1450 TTB Ranger
Thanks were just going to cut the beams to lower the front down and put bags on the back.Hauls Assington wrote:Also, my next build is a slammed f-100 for my wife, that is a sweet one you got there!
there is a guy on DR that sells brackets that let you bolt the d44 on. I don't think a cut & turn is needed at that point. Not positive.
Here's the link for the brackets I mentioned.
http://www.dezertrangers.com/vb/fab-shop/109428.htm
There is also this...
http://www.dezertrangers.com/vb/parts-a ... 216752.htm
As for this - you mean cut the coils I assume? If so, the camber will be pretty nasty. How are you going to correct that? Bend or pie cut the beams????Smith racing wrote:Thanks were just going to cut the beams to lower the front down and put bags on the back.Hauls Assington wrote:Also, my next build is a slammed f-100 for my wife, that is a sweet one you got there!
Oh and if we had edit back these last 3 posts could have just been in 1 post.
When I got the truck the coils were already cut so the camber was already mest up, yea were going to extend the ends of the beams and pie it to correct the camber.ChaseTruck754 wrote:As for this - you mean cut the coils I assume? If so, the camber will be pretty nasty. How are you going to correct that? Bend or pie cut the beams????Smith racing wrote:Thanks were just going to cut the beams to lower the front down and put bags on the back.Hauls Assington wrote:Also, my next build is a slammed f-100 for my wife, that is a sweet one you got there!
Well guys I went and steam cleaned all the parts I had, ttb, transfer case, and a few others. The ttb and the ford 9 inch should be getting trussed soon, but nothing major is going to happen until we do this next race with the bronco and then it goes up for sale. Knock on wood that now ive said that noting bad happens.
- Clean parts
- 20150214_130145.jpg (161.01 KiB) Viewed 3051 times
Well we still have plains for the 4x4 ranger but just as a chase/prerunner, this is going to be the new race truck. It has a 3 link in the back, were going to pull out and put a 4 link in with a fresh 9inch, and the front has custom 1inch kingpins with swinger set-up steering. It has the stock 3.0 in it still with a manuel, we have plans for a 302 swap in the future, but for now were going to make this motor run on the bare minimum, and I was wondering if any one made a smog delete kit for that motor. The bronco on the other hand will be going up for sale soon to pay for the new truck, i dont know when but if you see it on racedezert this is why.
- Stock
- 1428796172253.jpg (150.65 KiB) Viewed 3014 times
- 1428796148432.jpg (141.62 KiB) Viewed 3014 times
- Engine
- 1428796118824.jpg (160.21 KiB) Viewed 3014 times
- Front
- 1428796088554.jpg (102.07 KiB) Viewed 3014 times
- New toy
- 20150411_173454.jpg (137.41 KiB) Viewed 3014 times
Well that escalated quickly, my son pulled the whole rear end , links and all last night, then today pulled front shocks, removed window, and a list of other things.
- 20150411_220617.jpg (113.87 KiB) Viewed 2995 times
- 20150412_120434.jpg (157.36 KiB) Viewed 2995 times
- 20150412_120440.jpg (138.17 KiB) Viewed 2995 times
- 20150412_193131.jpg (157.99 KiB) Viewed 2995 times
Well heres a little update, engine has been stripped all AC components and pulled the water pump because the clutch fan is froze on and to do that I had to pull the power steering pump to get the last bolt, who ever designed that needs to go back to school and not make it so complicated. We also pilled the seats and a few little things. Heres a pic of the rear axle were building.
- Axle
- IMG952466.jpg (225.62 KiB) Viewed 2970 times
- Interior
- 1429156895685.jpg (129.9 KiB) Viewed 2970 times
- Engine
- 1429156838468.jpg (160.61 KiB) Viewed 2970 times
- Hauls Assington
Nice! Looks like you are well on your way!
Was that a truck you all already had?
It was my brothers and he put it up for sale so we got it and are making it the new race truck, since its already caged and has already been linked, so were just upgrading it besides building a whole new truck.Hauls Assington wrote:Nice! Looks like you are well on your way!
- Hauls Assington
Sweet! I am going to go for a drive in the bronco this weekend, if I can get my buddy to let me borrow his nitrogen, to charge the shocks.
- Hauls Assington
I started it under its own wiring, and I am happy to say that the motor sounds extremely beastly!
Sweat man thats great, im looking forward to seeing this thing, if and when you go out get some video footage so we can see this thing in action. Just make sure everything is all snugged up.Hauls Assington wrote:I started it under its own wiring, and I am happy to say that the motor sounds extremely beastly!
Rear axle all done up.
- 20150423_183228.jpg (134.25 KiB) Viewed 2922 times
- 20150423_183215.jpg (131.79 KiB) Viewed 2922 times
- Hauls Assington
Nice! this thing is coming right along!
Junk yard find of the day: A 1990 ford 5.0HO with hydrologic lifters and forged pistons. With a good set of heads and a cam, and I need to find a small block c6 now.
- 20150531_193530.jpg (156.23 KiB) Viewed 2868 times
- 20150531_193538.jpg (172.21 KiB) Viewed 2868 times
- Hauls Assington
Excellent!
Hauls Assington wrote:Nice.
I am working on my roll cage right now, I wish your brother was down here helping me! I got the A-pillars bent, and b-pillars cut, I have the mounts made, and holes drilled.
What roll cage regulations are you going with?
Nice truck!
