Wanted....a pair of factory alcoas, and a D44 snout
As the title says...two alcoas, and d44 snout and hub assembly.
Re: Wanted....a pair of factory alcoas, and a D44 snout
5 or 6 bolt is fine, I think a pair of 5 bolts would bolt right up to the D35 uprights I have though...
The snouts and hubs are for me BTW.
I paid for a pair from mafia john I never picked up if you want to grab them . I believe there in la habra or Whittier.
That would be awesome. Do you know the bolt pattern? Apparently the 5 bolt will bolt right onto my about block without any modification other than moving a caliper mount!
These are 6 bolt snouts , I'll pm you his phone number when I get home. See if he minds if you grab them. I have a set of 5 bolt snouts at my place . We'll get it figured out .
I can modify your uprites if needed.
If you'd be willing to sell the 5 bolt snouts that'd be choice lol. If you don't want to part with them, let me know what you want for the 6 bolts and I'll figure out how much extra work it'll be to modify the uprights. The issue is redrilling and tapping the new holes square.
Grab a set of calipers, measure bolt hole diameter and spread between 2 of them and you can use a bolt circle calculator to figure out what snout you need. As I recall a d44 and d35 are not interchangeable. I can modify what you have to accept anything you want to run. Anywho... The set of 5 bolt snouts I have here are pretty beat. They have been cleaned up some but they were allowed to rust solid before I got my hands on them. Ive been using them for measurements mainly .
According to this: http://www.dezertrangers.com/vb/fab-shop/167324.htm
They should be the same bolt pattern.
