Pro Comp 4" spring
HotRod82
Bronco Info: 99 Explorer -Dixon Front, Giant 64 rear.
Pro Comp 4" spring
Post by HotRod82 »
For those of you running this spring, how much did they settle? I installed a new set on mine and they are really tall, I'm hoping they will settle down some. Anyone have experience with this?
Agui-E7TE
Re: Pro Comp 4" spring
Post by Agui-E7TE »
I installed them on my Bronco and the front was pretty darn level with the rear which has a set of Deaver F53s as well as a 3.5-inch angled lift block. I took it out to Glamis for New Years and once I got back home I immediately noticed that the front was at least an inch and a half lower. They will settle quite a bit after beating on them in the dirt but that is to be expected since they sit taller than the advertised lift when they are new.
I have had the same set on my bronco for over 100,000 miles ,and a ton of hard use,they have settled about 2"
Well over an inch
HotRod82
Post by HotRod82 »
Good to hear, thanks. I went from a 6" to the 4" when I rebuilt my front end and it is sitting nearly the same as it did with the 6".
Polarcub
Post by Polarcub »
1"-1.5" mine lasted about a year and half before they collapsed on the the top 3 coils.
