Danny's 95 Bronco
DANNYV
Bronco Info: 1995 XLT
Danny's 95 Bronco
Post by DANNYV »
SO i finally decided to start a build thread . Hoping you guys could give me a little of extra help when i need it.
Here's a little run down.
95 bronco 351w with headers and an intake.35'' tires has 456 gears.
Front end
Solo motorsports radius arms and engine cage .4.5 extended beams extended by me with 14'' coil overs .
Rear
Deaver f53 saw 12'' bypass shocks extended shackles .
I try to do as much fab work as i can on it. Its defiantly been a learning experience .
Back when it was stock
When i first started out. Now looking back i wish i didn't extend the beams :( .
After extending the beams .Working on mounting the fenders
First shock hoop . lasted for about a year.
Second one . Way stronger than the first one .
Rear axle carnage
current pic
As of right now i am building up a 9'' rear end. econoline housing bought from someone on dr and a 3rd member i bought form mike.Waiting on Currie axle shafts.
I cant wait to get it up and running again! :D
Re: Danny's 95 Bronco
How much wider in width will your rear end result to?
DANNYV
Post by DANNYV »
The axle on my bronco is 65wms to wms and the 9'' is 68wms to wms so it will be 1.5'' wider per side.
