A/C airbox
Polarcub
A/C airbox
Post by Polarcub »
Hey guys I am looking for an A/C airbox for my 95 so I can cut it down. If anyone has one or knows where i can get one I would be much appreciative. I think I need to make a junkyard trip.
Jeremy
bajacowboy
Bronco Info: 89 Bronco 4inch over beams, currie rear axle 5 inch over, BFG projects.
Re: A/C airbox
Post by bajacowboy »
i have one frma 86 bronco not sure if it will work for a 95 but its complete and still all hooked up and blows cold.
tvoymang
Re: A/C airbox
Post by tvoymang »
I have two of em. One off a 95 f150, which will be best for you since its r134 not r12. $100 with lines pulled and ready to go.
Pm me if interested.
Polarcub
Re: A/C airbox
Post by Polarcub »
Got one coming guys Thanks Bajascott!
Jeremy
flyinbronco
HuckMASTER
Re: A/C airbox
Post by flyinbronco »
Just a heads up. There are very minor differences between model years and even between years. I grabbed one from a wrecking yard, oops, dismantler off the same year and the tube coming out of the box going to the condensor hit my Autofab coil bucket. They looked the same but enough of a difference to make it useless.
cuz_im_CR
Bronco Info: 96 xlt stock
Re: A/C airbox
Post by cuz_im_CR »
flyinbronco wrote:Just a heads up. There are very minor differences between model years and even between years. I grabbed one from a wrecking yard, oops, dismantler off the same year and the tube coming out of the box going to the condensor hit my Autofab coil bucket. They looked the same but enough of a difference to make it useless.
Well now you tell me!!!! Haha thanks for the reply and that is great info...
I have a 96 and used a box off an 1990. The line that goes from the box to condenser has different size fittings on each end so I just had a line made to work. I also replaced the dryer/accumulator with a R134 one.
Now that everything is back together it worked great for a couple days and now I only have the blower motor work on the high setting. 1 2 3 don't work. Only 4
Re: A/C airbox
That's the resistor. Mine went out and it only worked on high and off. Under the condenser there is a plug that plugs into the AC box. That's the resistor. 2 screws takes it off.
