COOLANT LINE
THEJESUS
Bronco Info: 1992 BRONCO XLT
COOLANT LINE
Post by THEJESUS »
NEED THIS PART FOR MY BRONCO AS YOU CAN SEE IT IS ALL CORROSION GOING ON.. NEED ASAP LOCAL PICK UP IN MURRIETA/TEMECULA/ ELSINORE WOULD BE PERFECT.
PLEASE CALL OR TEXT ME IF YOU HAVE IT 951-760-0141
biggiek
Bronco Info: 92 Ford Bronco
Re: COOLANT LINE
Post by biggiek »
I would cut it and put hose over it. But I've bought motorcraft kt-8+ as my replacement.
S00TLYFE
Bronco Info: IT RAPTOR NOW
Re: COOLANT LINE
Post by S00TLYFE »
Econoline one worked for a buddy
THEJESUS
Re: COOLANT LINE
Post by THEJESUS »
THANKS GUYS. FORD ACTUALLY STILL MAKES THE PART HERE IS THE PART NUMBER #E8TZ-18B402-C
