nubreed71
Post by nubreed71 »
Bump pics
S00TLYFE
Bronco Info: IT RAPTOR NOW
Post by S00TLYFE »
thing looks rad taylor, give me your bumpers, I know you've found a new idea youd like to try.
nubreed71
Post by nubreed71 »
Hahahaha, nope, still loving the front and rear bumpers on this thing. They're keepers!
That's where I was thinking of putting the upper shock mount on mine. Let me know what you end up with so I can copy what works haha.
nubreed71
Post by nubreed71 »
Will do. Right now those are 3.0x10" stroke smooth bodies. I was digging around on the net and figured out that the 3.0 bypasses that Fox sells for the Raptor actually have a .5" shorter compressed length than what I have, but a 1" longer extended measurement, so I may try to find a deal on a set of those and swap em on down the road to get a bit more droop travel.
S00TLYFE
Post by S00TLYFE »
Travis don't you have a set of raptor take offs for sale?
nubreed71
Post by nubreed71 »
I actually need the upgraded 3.0 ones that Fox does. Thanks for asking for me though!
So with spring under a 2 link isnt necessary or do you have something else in mind?
-shockseals.com
nubreed71
Post by nubreed71 »
As it's been explained to me, spring under takes care of the issues with axle wrap, and a 2 link is not needed.
S00TLYFE wrote:Travis don't you have a set of raptor take offs for sale?
I was planning on using them not selling them! So I want to see how this goes down :)
nubreed71
Post by nubreed71 »
Do you have an eye to eye measurement on the stock takeoff raptor rear shocks? I'm curious to see how it compares to the 3.0 fox bypasses that they sell in the aftermarket.
This is what I measured eye to eye
Raptor shocks
18" collapsed
29-1/2" extended
11-1/2" stroke
nubreed71
Post by nubreed71 »
Yup, those are the same measurements on the aftermarket 3.0 bypass. Interesting...
nubreed71
Post by nubreed71 »
Do the upper and lower shock eyes have bushings in them? Any idea what the mounting width is? 1.5"?
Look into the King external threaded cap and welded end, very short.
Have they said why not mount the shocks on the outside of the frame? Seems like it would up the stability if not just a little.
Still looks killer though :-)
nubreed71
Post by nubreed71 »
Would be way more expensive to go outside the frame rails.
nubreed71 wrote:Do the upper and lower shock eyes have bushings in them? Any idea what the mounting width is? 1.5"?
Yes, bushings and 1.5" width.
nubreed71
Post by nubreed71 »
Awesome, thanks for the info! Might have to use those for mockup til I can find a deal on a set of the 3.0 bypasses.
