Mom & Dad's Thanksgiving Bronco
1Hondalover
Re: Mom & Dad's Thanksgiving Bronco
Post by 1Hondalover »
September 2016? Trying to get back on track......an alternate E4OD mount?
A warmed over 5.8 swap happening to Mom & Dad's Thanksgiving Bronco any day now. Some new pieces to go along with it, including some Solo Boys' motor mounts. Then I'm thinking about the transmission mount. Not too many options other than OE type or the race piece from Autofab. This isn't the Prerunner, so John's piece is overkill. Bobby says they're having the best luck with the Anchor OE copy, but it looks kind of nasty. Deceptively heavy duty with the giant steel surround but joined with comparatively little rubber isolation.
I'm looking around. There's got to be another alternative. An Energy Suspension #4-1104 shows up on my screen, looking remarkably as shapely as the nasty. It's for a Mustang but still a Ford. Buy it too. Good eye......the polyurethane wonder is the same, with one notable difference. The nasty has 1/2" studs while the Poly has 7/16" internal threads. Before you get to it, I know a Mustang doesn't thrash a transmission like a Bronco and may not cut the mustard but I'm going to quiz Energy for their thoughts on it.
Any other thoughts?
IMG_5490 (Large).JPG (319.55 KiB) Viewed 2758 times
IMG_5489 (Large).JPG (354.26 KiB) Viewed 2758 times
IMG_5491 (Large).JPG (253.25 KiB) Viewed 2758 times
IMG_5493 (Large).JPG (277.28 KiB) Viewed 2758 times
IMG_5494 (Large).JPG (224.79 KiB) Viewed 2758 times
Energy Ssupension 4.1104.JPG (35.95 KiB) Viewed 2758 times
1Hondalover
Fingers crossed......Mom & Dad's Thanksgiving Bronco was dropped off yesterday at Full Throttle Kustomz with some of its new guts. Hopefully this will save some time and headache with everything from swap to dyno under one roof.
IMG_6609 (Large).JPG (473.36 KiB) Viewed 2656 times
IMG_6614 (Large).JPG (327.31 KiB) Viewed 2656 times
IMG_6618 (Large).JPG (310.16 KiB) Viewed 2656 times
IMG_6625 (Large).JPG (342.27 KiB) Viewed 2656 times
IMG_6714 (Large).JPG (234.39 KiB) Viewed 2656 times
IMG_6723 (Large).JPG (281.63 KiB) Viewed 2656 times
Hey Jim, just getting caught up over here, great looking project so far...what was done to the "warmed over" 351?
1Hondalover
Everything within reason that will pass any smog test with no games Robert. FTK is putting the 56MM BBK on it, and it was fit with its new F150 "ram air" intake before delivery.
It will be interesting to see the dyno results of this engine compared to what it spun when OE with the "illegal" Bassani setup and other toys under the hood of Jim & Paige's Bronco.
1Hondalover
New engine in and running around gathering 1,000 break-in miles before we go to final dyno tuning on the 7th. I'm going to put a 4.10 R&P temporarily in the rear so the tuning happens on final gearing. Funny how much quieter it got, even with the headers. Sort of a tight solid sound unlike we're used to coming out of a 22 year old Bronco. Sure pulls nice.
What an unbelievable difference the Red Head box and Borgeson steering shaft made.
IMG_6861 (Large).JPG (309.22 KiB) Viewed 2542 times
IMG_6862 (Large).JPG (327.21 KiB) Viewed 2542 times
IMG_6863 (Large).JPG (290.44 KiB) Viewed 2542 times
IMG_6870 (Large).JPG (347.27 KiB) Viewed 2542 times
IMG_6868 (Large).JPG (292.2 KiB) Viewed 2542 times
Jim -I’m curious to know how that new steering shaft connects to you stock steering column? I just found out today that my lower steering u-joint is the wrong spline for flat Saginaw box so I’m thinking about a whole new unit.
1Hondalover
Not exactly sure what you're asking Matt.....does this help?
https://www.fullsizebronco.com/forum/7- ... sults.html
I’m so dumb I figured it out.
1Hondalover
So we got a bit of extra twist with the new engine and its few E.O. parts. We'll call it good enough for my DD and for Mom & Dad to cruise in Baja now 2019. We had a used Ford 4.10 R&P stuffed in the rear to make sure we were tuning on final gearing. Calcs not included on the dyno report put the crankshaft numbers at 283 HP and 423 TQ. Boy we sure could raise those numbers with an intake and some heads, but it runs pretty damn good and maybe best of all doesn't leak a drop of oil any longer! Awesome pieces, but I'm not sure the Solo motor mounts were the best idea in this rig. Definitely makes it feel a little "harder" going down the road.
Dyno 1.JPG (70.04 KiB) Viewed 2292 times
Dyno 2.JPG (60.34 KiB) Viewed 2292 times
LvSteve
Post by LvSteve »
Nice what software was used
1Hondalover
SCT.
Becks_Bronco
Post by Becks_Bronco »
This is exactly how i see my build going down, then taking the long road to saving up for a coilover conversion up front.
Becks_Bronco
P.s. more details on exactly what you did with the motor. Fellow CA prisoner here.
