Extended bronco
Re: Extended bronco
I had one, I think I remember the window being one piece. Pretty sure you can swap in newer style windows. The cab I had for the aborted "Long Bronco" project was a jail window cab.
1Hondalover
Re: Extended bronco
Post by 1Hondalover »
So it appears the 91 and earlier "split window" Supercab is two separate pieces of glass set into the body piece pushed into the hole from the outside.
Which could I guess be the same hole that used a single piece of glass with standard rubber surround 92 and newer.
1991 Ford F150 Supercab split window outside.jpg (208.05 KiB) Viewed 1876 times
1991 Ford F150 Supercab split window inside.jpg (198.12 KiB) Viewed 1876 times
