Project Double Trouble/Drew's Bronco
Re: Project Double Trouble/Drew's Bronco
12 to 15 bucks ground
drewbee88
Post by drewbee88 »
got some quality time in at shop last night, got B-Pillar Tacked to body for now, and bot A-pillars notched and tacked in!
A pillars tacked in.
drewbee88
Post by drewbee88 »
Oh and BTW still runs and drives! hahaha
Right on!! A pillar tube looks nice and tight!! Are you planning to run a pontoon setup to the frame?
drewbee88
Post by drewbee88 »
tcm glx wrote:Right on!! A pillar tube looks nice and tight!! Are you planning to run a pontoon setup to the frame?
yeah pontoon/rocksliders, plan on doing some wheeling with this thing too. the B-pillar land directly above the front spring hanger.
89bronco.jake
Bronco Info: 1989 bronco
Post by 89bronco.jake »
with the A-pillar going right there, will it take away that AC ducting behind the vent? only reason i ask is i have the exact same bronco as you and plan on caging it pretty soon, but wasnt sure if i wanted to go on the side of the dash or go behind it since i dont wanna mess with the AC ducting.
drewbee88
Post by drewbee88 »
89bronco.jake wrote:with the A-pillar going right there, will it take away that AC ducting behind the vent? only reason i ask is i have the exact same bronco as you and plan on caging it pretty soon, but wasnt sure if i wanted to go on the side of the dash or go behind it since i dont wanna mess with the AC ducting.
So far just loosing defrost/mirror vents until I fab a new vent for it, the defrost tubes unbolts and you can snake the dash bar back there too, may have to heat up vents on passenger side, but shouldnt be too bad! Who needs defrost and mirror vents anyways
drewbee88
Post by drewbee88 »
And if you get it tight enough to the body you don't have to move e brake at all, as it it right now e brake is staying in stock location
ChaseTruck754 wrote:4130 corp 14 snouts from Ballistic
http://www.ballisticfabrication.com/Ful ... _1697.html
Ruff Stuff has 14b snouts as well (he says stronger) - $8 cheaper than ballistic.
corp 14 aluminum hubs - ballistic (8 lug!)
http://www.ballisticfabrication.com/Alu ... _1695.html
Wow, that whole post should be made into a sticky in the tech section.
Thanks for ruining My day with the 14B stuff, I had no idea that there were hubs and snouts available that cheap..........
How did it ruin your day? Were you making your own, or planning on making some to sell?
And on that note - had any free time to whittle stuff down & make chips fly?
drewbee88
Post by drewbee88 »
Got a good day in today at the shop, got a lot more done on cage going to fit a few more tubes then I will be moving onto front suspension.
Lookin good!
drewbee88
Post by drewbee88 »
Fitted a few more tubes today, Also cut holes in firewall for engine cage to cab cage tie ins
drewbee88
Post by drewbee88 »
Picked up some good parts today, made a loop around northern ca to pick up stuffs!
Pit stop 1!
Pit stop 2
big-d
Bronco Info: 1987 F150, 351W/418 Stroker, E4OD, F250 1356 W/fixed yokes, Sterling 10.25, D50 TTB 4" over
Post by big-d »
Are you going to use the entire D50 TTB or just put the ends on 44 housings?
I am in the middle of putting 4" over D50 housings under my 87 F150 with the sterling 10.25 rear.
drewbee88
Post by drewbee88 »
big-d wrote:Are you going to use the entire D50 TTB or just put the ends on 44 housings?
i will be using the dana 44 beams and extending with the outers of dana 50's, then plating and a truss, using dana 50 third memeber and extended axles
drewbee88
Post by drewbee88 »
Pallet O ttb, sock picked up another complete set of Dana 50 ttbs, gotta get another truck out of the shop before I can get bronco up on stands and start on the beams/engine cage
drewbee88
Post by drewbee88 »
So I have been getting cage work finished up! Starting front suspension soon! Picked up this guy today as a second car! DD family wagon. Super clean and low miles! Super stoked! Gonna be shreding this thing to Pismo for huckfest! If y'all see me stop by and say howdy!
What are you going to do for your E Brake and Steering Column support?
drewbee88
Post by drewbee88 »
Tube slides in between cab and e-brake, so ebrake bolts up just as it did before no modification needed
