Hmm, the bulb looks different than mine. Is Tony using a different projector/bulb these days or is there just no projector? I love the look of these lights.Rmc wrote:Hid's all the way across thx to tony, and I swapped out the yellowing factory lenses for these.
RMC's el hefe build.
- Kel Fab Creations
- Bronco Info: 95 Bronco
Re: RMC's el hefe build.
No these are just off the shelf crystal headlights, tony is putting a true euro style projector in these housings. The pattern would be like a BMW or one of the true projection style headlights. I just saw these n thought they would look way better than stock. They seem to work ok but I have only had them on for adjustment. I have yet to drive any distance with them. when I get a little extra cash I will buy Tony's but regearing the axels takes precedence currently. I absolutely have to do the gears after I put the 37's on it. My gas mileage is pretty bad.
It's about time!I found my egr problem,loose pin at the egr vacuum sol. I've only had the solenoid 4 months n finally got around to swapping it out. Stupid ass dumb luck lol. Now on to my oil n water leaks...
Man no matter what ive done ive never been able to keep mine from leaking.
Bad news, just found my lil water leak, it started after I changed the water pump... Now it's leaking from the seam of the timing cover... This is gonna be a long night I have a feeling. Hto ill post a pic of the connector with the pushed out pin, just one thing to have a look at.
Thats a thought. When mine went bad it was sticking real bad but i didn't think the pin.
Grumble grumble... Down to the harmonic balancer n crank pulley.
- image.jpg (236.99 KiB) Viewed 2126 times
At least you didnt have to fix a broken stud! I swear thats the worst.
- Kel Fab Creations
Broken/deteriorated thermostat housing bolt. That one took me a while. And I remove broken aircraft fasteners (among other things) for a living. LOL.hobbyturnedobsession wrote:At least you didnt have to fix a broken stud! I swear thats the worst.
So 20 hrs later, I fixed every leak on the engine. An oil change, new oil pressure switch n new coolant. I also found a big ass hole the sheet metal cut into my k&n filter
ordered a replacement tonight. Everything is back up n running now so my sore back was worth it. Also weekend before last we went shooting to test my brother in laws new mossberg 935, (nice shotgun btw) I took some cool pics, found an old gold mine and captured a horney toad for the kids. Apparently none of them had ever seen one in real life. I kinda felt like a kid agian trying to catch the fat little guy. It was a good day and thought u guys would like to see the photos.
- image.jpg (122.51 KiB) Viewed 2068 times
- image.jpg (125.33 KiB) Viewed 2068 times
In the center of the valley is my brother in laws car way down there. That's the mine shaft and my brother in law up on the hill looking down it.
- image.jpg (120.45 KiB) Viewed 1974 times
- image.jpg (149.45 KiB) Viewed 1974 times
- image.jpg (118.28 KiB) Viewed 1974 times
Hard to see in the photo but the mine went into the hillside over 100ft. U can barrely make out my brother in law in the black shirt looking into the mine shaft above the pic with the bronco in front of the mine entrance.
- Tanner287
Love your bronco! How much over per side are your beams?
Thx bro
4.5 threat kit.
- Tanner287
How wide are you from out side to outside of the tire? Cus your on 37's right? And what's the back spacing on those methods?Rmc wrote:Thx bro4.5 threat kit.
I'm curious because I have solos 4.5 kit and I have a lot of glass to fill and I sure hope I can fill it out haha
4.5 backspace trail ready bead locks, 4.5 extended beams, 3.5 bulge glassworks fenders up front, 37x12.5-r17 Goodyear mtr's (there more like 13" or so with side lugs), 2" wheel spacers in the rear till I swap to 9". U may have 4 or 6 inch front fenders. Ill measure the track width after work.
- Tanner287
Oh ya I forgot you had trail readys. My glass is supposably like 78"s wide
Ok just measured, 78" track. It's gotta be the glass that makes it look different.
- Gregsbronco13
- Bronco Info: 1992 5.8 white pretty stock for now
Is that mine up in apple valley? Looks like the one I found while riding my bike
