The Flyin Filarski's TTB Jeep XJ
Re: The Flyin Filarski's TTB Jeep XJ
Nice work man!!!
4x4_mafia_jon
Bronco Info: all stock on some 33s.. just crossed over from the rock crawler dackside
Post by 4x4_mafia_jon »
this xj is bad ass.
i have one sitting waiting for a tcase
FatCity
Bronco Info: 03 F150
Post by FatCity »
Not much to update. finished all the plate work on the beams. Made the clocking ring and clocked the diff to compensate for the cut and turn.
Knocked out the truss and just need to finish some welding before it all goes back under the car.
Super clean. I like your plate work.
FatCity
Post by FatCity »
We got some Father’s day garage time passes this weekend.
Ryan and I worked on getting the radius arms built so we could cycle the suspension for and get the shocks mounted.
We started with 1-3/4 tube and then worked on the plate work.
We cut a window in the top of the driver side arm to make the two side mounting bolts more accessible.
FatCity
Post by FatCity »
Once we had the majority of the radius arms made up, we started working on the shock mounts.
After cycling the beams we mounted the lowers at about a 45* angle to make sure the shock rod end didnt have any bind.
Nice! Great work!
Very cool, nice progress.
far out man!!!
I see an EPIC XJ in the making!!
Great work as usual guys!! I can't wait to see it in person. What do you think it'll end up cycling? I have seen many on here angle the top mounts of the shocks too.... is there a benefit to that in your eyes?
FatCity
Post by FatCity »
Silverslk wrote:Great work as usual guys!! I can't wait to see it in person. What do you think it'll end up cycling? I have seen many on here angle the top mounts of the shocks too.... is there a benefit to that in your eyes?
It cycles 17-3/4" and we figure we'll strap it at 16'sh.
We cycled it both ways, with and without the tops angled. And we decided it did change enough to bother with it.
An XJ with 16+" wheel travel is gonna do some good things!! That stupid solid axle has always been the pain with those things and good travel vs lift height.
Kel Fab Creations
Bronco Info: 95 Bronco
Post by Kel Fab Creations »
Nice progress. Looks awesome.
FatCity wrote:
Silverslk wrote:I have seen many on here angle the top mounts of the shocks too.... is there a benefit to that in your eyes?
Correct ^^^^^ It only really matters on the bottom mounts.
Nice looking Heep.........
FatCity
Post by FatCity »
Kel Fab Creations
Beautiful!
Best XJ ever!!!
groovy as all get out man nice job gents!
FatCity
Post by FatCity »
We got busy on a couple other jobs for the last couple months, but were able to get a few things done...
We got some of the Charlie Brown done and added another tie in from the a-pillar.
We finished the cross member for the most part by capping the top and bottom and outsides.
