Ryan's '96
- RyanDS650X
Re: Ryan's '96
Ive got the solid ones judging by the pics on autofabs page.
http://autofab.com/c-335581-motor-mount ... ronco.html
-shockseals.com
-shockseals.com
Re: Ryan's '96
yeah - you've got the ones for the later trucks, not the eb-302 ones. Free is an UNREAL deal on those! Now get them in the truck.
Re: Ryan's '96
RyanDS650X wrote:So i havnt done much aside from maintence lately... replace a header gasket, cleaned out the IAC and throttle body now my idle is back to where it should be. This week is front break pads and maybe motor mounts before i head to Primm for the Henderson 250.
Maintenance is boring, but so is being broken down..... nothing but good stuff going on Ryan making sure she runs tip/top!!
Re: Ryan's '96
Maintenance sucks.. Especially when your fixing others mistakes
- RyanDS650X
Re: Ryan's '96
Forrest wheelin with Mom and her pink sammi. Great day and awesome weather!
- uploadfromtaptalk1358634283967.jpg (106.43 KiB) Viewed 3165 times
-shockseals.com
-shockseals.com
Re: Ryan's '96
Bronco looks great a little Sloppy Ryan. Looking forward to seeing it at KOH.
- RyanDS650X
Re: Ryan's '96
Thanks Tony, i like playing in the mud but the clean up.... not so much. Cant wait for KOH!tcm glx wrote:Bronco looks great a little Sloppy Ryan. Looking forward to seeing it at KOH.
-shockseals.com
-shockseals.com
Re: Ryan's '96
Tell me about it. After the 1000, it was 10 dollars at the quarter machine just to start. Then two or three washes more to get it back to mall crawler status.
- RyanDS650X
Re: Ryan's '96
Ive had a great week off enjjoying the hell out of my Bronco! Started off with a few days at King Of the Hammers and finished up out at the sand drags at a local MX park. Good times!
Day 1 gopro incab at KOH
Day 2 gopro bodymounted at KOH
Carnage update was just a leaky fitting on my rear axel for the air locker and my AC compressor wont engage. Overall a great week with good friends and lots of dirt!
- RyanDS650X
Re: Ryan's '96
Sand drags at ET Motopark. I made 4 passes and won them all.
- Winner.jpg (160.05 KiB) Viewed 3058 times
Re: Ryan's '96
Alright Ryan!
323bronco
- Bronco Info: 1989 BRONCO TTB with 96 front clip
Re: Ryan's '96
Right on Ryan GO FAST!!!!!
- RyanDS650X
Re: Ryan's '96
Thanks fellas. That was my first time at the drags and launching off a tree like that. Im just glad i didnt red light haha. Ill be back there for sure it was a blast and the people were cool too.
Re: Ryan's '96
Sweet! Id like to try that one of these days. It looked like hard pack. Did you use 4 wheel or 2 wheel drive?
- RyanDS650X
Re: Ryan's '96
It was soft sand but if you keep your tires in the groove and werent the first on the line after they grade it there wasnt much wheel spin. I ran 4low and both axels locked at around 30lbs tire pressure. No power brake just stabbed the gas on green. It was a 300ft drag and id hit 4th gear right as i went through the trap. Good times for sure!
- David Kennedy
Re: Ryan's '96
How much different does it feel with the axles locked ?
- RyanDS650X
Re: Ryan's '96
VERY different. The handling is very tight and it goes exactly where you point it. I scared myself the first time i launched fully locked.... it slams you into the seat and just rips up the track.
- RyanDS650X
Re: Ryan's '96
More maintence update. AC pump wouldnt turn on, did a voltage check at the connector in normal and max modes and had no reading. Fan and thermostat work fine but the selector in the cab wasnt sending power to the compressor, checked the in cab fuse and it was good also. Pulled the ac selector panel out and removed the switch behind the knob. Went to 4 parts stores and struck out... partsgeek.com has one and it should be here early next week.
- uploadfromtaptalk1363385440495.jpg (49.94 KiB) Viewed 2904 times
- RyanDS650X
Re: Ryan's '96
Walked into the garage to take out trash and saw the Bronco sittin there in attack mode and just had to smile.... Anyone else do that??:P
Re: Ryan's '96
RyanDS650X wrote:Walked into the garage to take out trash and saw the Bronco sittin there in attack mode and just had to smile.... Anyone else do that??:P
Hell yeah!! NORRA next weekend, meet us in Mexicali!
