David Wright
The duralast agm is great got that in mine and no issues.Pickuptrucker wrote: ↑Tue Feb 02, 2021 2:44 pmDuralast agm batteries work great. So does no name rock auto agm, but it's only a year old so time will tell. I bought one Optima it crapped on before I even got to use it, and most expensive by far.
I'm on my 3rd 7.3 and I will not buy anything newer except maybe a newer 6.7 someday. My 02 is my 2nd dually, all stock, no tuning or anything besides a turbo back exhaust with huge magnaflow muffler just to let it breathe a little. Both trucks have been low mile tow pigs (2000 with 115k when it "left" and this one with 131k and counting).. I have had good luck with them but I drive very conservative, religious on OEM parts, and don't mind going slow up the hills, I dont care to be the first one to make it to camp, I wanna be the guy that gets there every time....Wrightracing.net wrote:I just did the injectors on my 1999 F350 7.3L but it has 200k miles on it and has been a great motor. This was the first motor issue. Now the transmission, I am on the second rebuild, but I am really hard on it with it in Baja and towing. This transmission is a major upgrade of everything that could be upgraded and switched to a manual shifter transfer case, so I have a neutral an can flat tow the F350 without dropping the driveline's.
Besides the Transmission, I have been happy with the F350. But I love my Bronco.
David Wright
My F350 just has a K&N cold air intake and a 100Hp tuner on it, which it made a great drivability difference and I got better fuel economy. Also, my F350 has been used for Chase truck duty in Baja for 19 years and the 37" Bfg Baja military beadlocks tires put a strain on the truck. But they get it in and out of everywhere I need to retrieve broken down race trucks.powa_ranga wrote:I'm on my 3rd 7.3 and I will not buy anything newer except maybe a newer 6.7 someday. My 02 is my 2nd dually, all stock, no tuning or anything besides a turbo back exhaust with huge magnaflow muffler just to let it breathe a little. Both trucks have been low mile tow pigs (2000 with 115k when it "left" and this one with 131k and counting).. I have had good luck with them but I drive very conservative, religious on OEM parts, and don't mind going slow up the hills, I dont care to be the first one to make it to camp, I wanna be the guy that gets there every time....Wrightracing.net wrote:I just did the injectors on my 1999 F350 7.3L but it has 200k miles on it and has been a great motor. This was the first motor issue. Now the transmission, I am on the second rebuild, but I am really hard on it with it in Baja and towing. This transmission is a major upgrade of everything that could be upgraded and switched to a manual shifter transfer case, so I have a neutral an can flat tow the F350 without dropping the driveline's.
David Wright
Sent from my LM-G820 using Tapatalk
I love it, sounds like a tried and true rig! I have personally seen them go 500k without pulling a valve cover, thats everyday use towing a concrete pump getting beat on, but then again my pops got his stolen a few months ago, 03 7.3 on 35's that he bought new off the lot, all stock with a turbo back and a whopping 83k miles, all hunting for the most part...it sat so much that the injector cups rotted out of it, they like to be driven apparently...but that truck got cut up by a chop shop and the only thing left was a door and hood, oh well.Wrightracing.net wrote:My F350 just has a K&N cold air intake and a 100Hp tuner on it, which it made a great drivability difference and I got better fuel economy. Also, my F350 has been used for Chase truck duty in Baja for 19 years and the 37" Bfg Baja military beadlocks tires put a strain on the truck. But they get it in and out of everywhere I need to retrieve broken down race trucks.powa_ranga wrote:I'm on my 3rd 7.3 and I will not buy anything newer except maybe a newer 6.7 someday. My 02 is my 2nd dually, all stock, no tuning or anything besides a turbo back exhaust with huge magnaflow muffler just to let it breathe a little. Both trucks have been low mile tow pigs (2000 with 115k when it "left" and this one with 131k and counting).. I have had good luck with them but I drive very conservative, religious on OEM parts, and don't mind going slow up the hills, I dont care to be the first one to make it to camp, I wanna be the guy that gets there every time....Wrightracing.net wrote:I just did the injectors on my 1999 F350 7.3L but it has 200k miles on it and has been a great motor. This was the first motor issue. Now the transmission, I am on the second rebuild, but I am really hard on it with it in Baja and towing. This transmission is a major upgrade of everything that could be upgraded and switched to a manual shifter transfer case, so I have a neutral an can flat tow the F350 without dropping the driveline's.
David Wright
David Wright
