Philo's 93 Bronco aka "Lucky Bronco #3"
Re: Philo's 93 Bronco aka "Lucky Bronco #3"
Finally replaced the motor mounts with the fabricated units...
- Kel Fab Creations
- Bronco Info: 95 Bronco
The Bronco worked well this weekend in Plaster City. I do have some issues however.
1. Steering box is leaking from sector shaft
2. Shocks need a rebuild and revalving.
3. Front tires now have flat spots from avoiding a head on collision.
4. Center u-joint spring and cap came off.
5. Truck now has death wobble issue when turning. May be 1-3, if not it's time for a single swing steer setup.
6. I need to change one of the springs on the coilovers to one with a longer free length, as the coil retainer/seat tried to fall out.
- BajaF250
- Bronco Info: 1982 Ford F250
Hey Philo,
How did the radio work this weekend?
philofab wrote:The Bronco worked well this weekend in Plaster City. I do have some issues however.
Details on #3
Awesome. I broke the mic casing since I didn't have a clip for it and didn't have a chance to grab one from PCI. Power and sound quality was great. Everyone could hear me from the far NE part of the course.BajaF250 wrote:Hey Philo,
On California 95 between Needles and Videl Jct I was doing about 80 mph and had a Nissan Altima try and pass a semi from the opposite direction. He couldn't make it for some reason and his hole closed up so I had to slam the brakes on to avoid him. Would have sucked.tcm glx wrote:Details on #3
- BajaF250
That would have ruined the weekend! Glad no one was hurt.philofab wrote:On California 95 between Needles and Videl Jct I was doing about 80 mph and had a Nissan Altima try and pass a semi from the opposite direction. He couldn't make it for some reason and his hole closed up so I had to slam the brakes on to avoid him. Would have sucked.tcm glx wrote:Details on #3
- BajaF250
philofab wrote:Awesome. I broke the mic casing since I didn't have a clip for it and didn't have a chance to grab one from PCI. Power and sound quality was great. Everyone could hear me from the far NE part of the course.BajaF250 wrote:Hey Philo,
Unusual... those mic casings are pretty tough... zap Darin and email and he may be able to help you out.
- BajaF250
Man Philo, those look just a tad rough.philofab wrote:Finally replaced the motor mounts with the fabricated units...
That was the third set. First time the drivers side had broken all the way in half. Still need to upgrade the trans mount, but I bet it will last longer now that it has good motor mounts.BajaF250 wrote:philofab wrote:Man Philo, those look just a tad rough.
- only1mikey
- Bronco Info: 84 Bronco
My motor was dancing all over the place this weekend. I need to do the same. Not looking forward to it.
Mike
Mike
Don't sweat it. The Autofab EB-302 mounts are a piece of cake to install.only1mikey wrote:My motor was dancing all over the place this weekend. I need to do the same. Not looking forward to it.
Mike
I installed these with a floor jack and couple of wrenches in about 20 minutes. You can get to every bolt from the bottom except the forward mount to engine bolt on each side. That required a ratchet wrench from the side. You could probably get it from the bottom with a CV or u-joint socket.only1mikey wrote:My motor was dancing all over the place this weekend. I need to do the same. Not looking forward to it.
- only1mikey
Oh ok cool I guess I am worrying for nothing.
Thanks guys.
Mike
Thanks guys.
Mike
Got some more parts for the upcoming DDL install.
Based on you saying "the DDL" - safe to assume those are Geoff's link mounts?
- only1mikey
Yep that's all Giant stuff.
Damn Philo you are going nuts on this thing.
Keep us posted
Mike
Keep us posted
Mike
I need to buy a bunch of hardware and the airshocks for it still. I haven't decided what I want to do for a front pivot... Uniball with insert, Kartek wobble stopper, regular bushings, ect.
I need to figure out how to add sway bar mounts and possibly airbag mounts to it too. Airbags would be nice when towing....
- only1mikey
Sway bar? isn't that the point of the airshock?
Mike
Mike
