I love dimples but there is definitely over use and dumb looking use. Like Steve said, take a little weight and add some rigidity to a plate.
Ford 4 US
Bronco Info: 96 and 79 (79 is a basket case right now)
Post by Ford 4 US »
Obviously not structural.... But remember louvers on cal bugs and mini trucks
Damn.... That went stupid......
I've seen the same thing on hot rods. I guess it's a "style" but seeing a rod with the entire trunk or hood louvered just kills it for me.
Ford 4 US
Post by Ford 4 US »
Now it is led lights.....
Pretty slick seat slider idea:
Notice the pull pin.
Pete Albano's Ranger had a similar set up. So simple but genius. I like!
That is pretty trick!
What type of business is that on the slider?
That is how I want to do my sliders on the driver's side. The difference is I am going to use 2 pull pins on each tube. Also the tubes will use Delrin bushings to ride on. I would not trust a single pull pin.
From what the dude was saying those are delin bushings it slides on. I think id use oil lite bushings (bronze with impregnated Teflon dry self lubricating)
Poly Performance sells a premade slider like that.
philofab wrote:Poly Performance sells a premade slider like that.
http://www.polyperformance.com/shop/Cha ... 30567.html
That is something else. The one I have slides on 1" tube.
That's cool I liked it's adjustability and it looks strong, I'll check poly performance. As you guys know I'm a cheap ass but I'm also a lazy ass so if cost outweighs time spent I'd gladly buy a set.
My buddy did the tube sliders ones like the 1st pic long ago in the 1 car due to driver size difference. They are cool for sure, but you have to be sure the tubes you weld in to the cage are square & that they do not pull at all during weld up or the sliders don't work well at all
Makes sence.
The Trophy Truck has those . The new Trophy Truck, has an actuator ! Push Button comfort !.
Buckin91
Bronco Info: 91 Bronco XLT
Post by Buckin91 »
cypher wrote:And yes it is Convoys old rig. It's a great bronco that Sean has made even better :D
Yup! My Bronco now and even better! Did some upgrades since I bought it from Sean and i'll have pics up soon.
Rmc wrote:From what the dude was saying those are delin bushings it slides on. I think id use oil lite bushings (bronze with impregnated Teflon dry self lubricating)
Oil lite is impregnated with 30W oil.
Delrin AF would be My material of choice for those.
Brian, is that the grey silver-ish delrin? The stuff with the kinda reflective ground up looking stuff in it?
