let me know when i can come pick the motor up.f150rick wrote:Correction motor and trans have 109k
1996 Bronco Part Out
Re: 1996 Bronco Part Out
I’m interested in trans. Message sent.
- Becks_Bronco
How much do you want for the Motor and/or trans?f150rick wrote:Correction motor and trans have 109k
Do you have the cardboard piece that fits under the rear carpet?
- Becks_Bronco
Which one Steve, i might have mine, and you can have it. I replaced everything underneath.SteveG wrote:Do you have the cardboard piece that fits under the rear carpet?
I need the piece that goes under the carpet... has cardboard slats to make the carpet flat instead of corrugated like the steel floor.Becks_Bronco wrote:Which one Steve, i might have mine, and you can have it. I replaced everything underneath.SteveG wrote:Do you have the cardboard piece that fits under the rear carpet?
- Becks_Bronco
I’ll check on Monday when I’m back at the shop, I don’t remember there being cardboard under mineSteveG wrote:I need the piece that goes under the carpet... has cardboard slats to make the carpet flat instead of corrugated like the steel floor.Becks_Bronco wrote:Which one Steve, i might have mine, and you can have it. I replaced everything underneath.SteveG wrote:Do you have the cardboard piece that fits under the rear carpet?
Got it. Thanks!Becks_Bronco wrote:I’ll check on Monday when I’m back at the shop, I don’t reme
- pat_car22
- Bronco Info: 1995 Bronco XLT 5.0-
What’s your number? I will be up your way on Thursday if you are around.. looking for headliner, front and rear and both door panels....
700Becks_Bronco wrote:How much do you want for the Motor and/or trans?f150rick wrote:Correction motor and trans have 109k
805-746-5367pat_car22 wrote:What’s your number? I will be up your way on Thursday if you are around.. looking for headliner, front and rear and both door panels....
Anything left?
