Been a looooong time since I actively looked at any of this, but form what I remember (Disclaimer - I'm getting old now, so my memory for random car parts isn't what it once was!) the 4L80 is a little shorter than the E4OD. And according to Culhane it was a much better trans for what we wanted to do with these things.
There definitely are drives side drop t-cases on the Chevies of I think the 2005ish era. I seem to remember the 241HD being the one I was looking at. I'm sure someone here may be more current on this stuff than I am though.
LS SWAP INFO
Re: LS SWAP INFO
LS SWAP INFO
Np241, bw44-01
Just have to get a slip yoke eliminator kit.
- funinthesun95
Re: LS SWAP INFO
the ford NP205 t case will bolt up to the TH400 and 4L80 just make sure it the ford.....drop
You need the chevy np205 stock adapter for TH400 as well it also saves length. yes it heavy but it gives you drive line.
Re: LS SWAP INFO
Kind of random, but just read this and found it interesting. Especially them saying they could have just run the junkyard LQ9 and called it good. Seems so tempting to just do that!
https://www.speedwaymotors.com/the-tool ... i_pc=may20
- S00TLYFE
- Bronco Info: IT RAPTOR NOW
Re: LS SWAP INFO
Since my truck is staying 2wd, I plan on going LS so i should have plenty of good info for you guys pretty soon
