Dario's daily driver!
Re: Dario's daily driver!
While I'm not really a fan of the overall style/look I can for sure appreciate the work going into the thing. Nice job on the tail lights etc.!
Agui-E7TE
Post by Agui-E7TE »
It does look like the hood is a bit nose high but it almost looks like it's a bit too long in the front but it could just be the lower piece under the grille. Are you planning on modifying the glass to sit lower?
-JD5353-
Post by -JD5353- »
I agree, if you could bring the nose down it would definitely make the front look much better. I am a fan of the rear glass and tail lights I just haven't learned to love the front yet.
valbros1600
Bronco Info: 94 bronco built for desert off-road pre-running.
Post by valbros1600 »
Thanks again and yes i am going to try and lower it. thanks for all the really good advice i really do appreciate it!....I think i'm going to throw black primer on it sit down have a Couple of cold ones and really look at it and figure out exactly what im going to do with it...on that bottom piece of the grill im goin to cut it a little and install that black trim they put on like trophy style i really think it gives it a clean look.
Bronco_Luis
Post by Bronco_Luis »
esta kedando chingona ehh .,aver kuando la vemos por ay .....
Mojo
Post by Mojo »
I'm definitely not a fan of conversions on any Broncos, but yours looks *AWESOME* and you did an amazing job. That being said, the center of the hood & grill is too high & I don't see a way to bring it down :(
Brad12
Bronco Info: STOLEN 1994 XLT, 6 in. Superlift, ext. RAs, 35X12.5 R15, TTB, 8.8, 351, 3.55, K&N
Post by Brad12 »
bajascott wrote:I think it is the hood that makes it look nose high. I like the conversion.
X2
Bronco was stolen in Berkeley, CA in 2014
I'm very slowly making my bronco go fast!
USA
valbros1600
valbros1600
Thought i would share another angle. Thanks for the compliments and thoughts i think i'm a little too desperate and just want to use it so i might start off by painting it all flat black to see just how it looks. I'll keep you guy updated! THANKS!!!!
It looks alot better from that angle.
hobbyturnedobsession wrote:It looks alot better from that angle.
I agree, I thought it was a picture showing you had "fixed" it. While I am usually not a fan of updating broncos, (Is it hypocritical that my 85 has 96 glass?) I think you have one of the cleanest swaps I have seen.
It looks great,I think that with paint it'll look good. You did a helluva good job! Thumbs up!
valbros1600
valbros1600
valbros1600
valbros1600
I installed that bottom trim on the front what do you guys think?...I'm EXTREMELY happy with how good it rides it's incredible how much noise all the bypass and coil overs make. Thanks for all the compliments!
DukeSky
Bronco Info: 92 4" Rancho, Procomp coils, Sagswa pump, 3G alt, 95 E4OD Built w/computer, locked
Post by DukeSky »
Dario it looks great!!! How did you attach the side mirrors? Like it alot.,
323bronco
Post by 323bronco »
That thing is awesome!!!! Dario very nice work.
Bitchin dude!
Agui-E7TE
Post by Agui-E7TE »
It looks great! I bet it's going to look absolutely awesome once you get some paint on it. I really like the bottom trim.. makes it look like a race truck.
