school me on ttb
stevelknievel
Bronco Info: 96 eddie bauer SAS'd and on 37s
school me on ttb
Post by stevelknievel »
Another stupid question. Guy at work has me toying with the idea of shrinking the truck and going down to 33s and maybe like a 2 inch lift. Would I be able to use the stock radius arms and stock mounts with a 2 inch lift? And what kind of travel could be obtained with the right tweaks?
Agui-E7TE
Re: school me on ttb
Post by Agui-E7TE »
Not sure on the travel numbers but I think I had mentioned this earlier about running a 2-Inch lift coil and some Bilstein 5100's or any other good shocks. You keep the factory pivots and you can also use your stock radius arms in their stock location. You will need some new eccentrics to properly align your wheels. Not sure what degree eccentric you will need though.
33's is the perfect combination with this and it will run a heck of a lot better than a stock suspension and you'll be surprised what a 2-Inch lift and 33's can do for a Bronco in the whoops.
