AWESOME! I love junkyard tech! Good find, thanks for sharing.
Same width as stock? Did you modify the stack at all? like taking out the overload?
Wheelbase stretch with minimal body mods?
- Bronco Info: 1988 EddieBoyEdition... Hungry for whoops.
Re: Wheelbase stretch with minimal body mods?
That's cool to see. What kind of work did you need to do to the hangers? Any sort or relocating? Any pics from underneath?
Thanks man.
Thanks man.
Found.Off.Road.Dominating.
- Bronco Info: 92 4" Rancho, Procomp coils, Sagswa pump, 3G alt, 95 E4OD Built w/computer, locked
Yes they are the same 3" width. I did change the overload spring to the Bronco overload because it is shorter. And these springs have 2 center pins so you can go short or long. Front pin moves it back about 1" the second pin location moves back the axle about 3". I went with the second pin location. Regarding the driveshaft I have a 30" and some change long compressed drive shaft and it work great but would like a wee bit longer at full droop. The next task I have planed is to remount my rear hitch and then move down the rear spring perches onto the side hitch plates that bolt to the frame like a Giant shackle relo kit would do and get longer shackles for some serious droop.Seabass wrote:AWESOME! I love junkyard tech! Good find, thanks for sharing.
Did not have to do anything. It was a complete bolt on. Hanger are in their stock location. I will send pictures of underneath the truck.Frontrunner54 wrote:That's cool to see. What kind of work did you need to do to the hangers? Any sort or relocating? Any pics from underneath?
Thanks man.
Right on... Have you measured for travel numbers? How's it do at 40+ in the dirt?
