Christopher's 1989 Four Door Bronco
Re: Christopher's 1989 Four Door Bronco
So when does the 92-96 update clip go on????
- Bronco Broker
Steve, I have every piece I need for the conversion but I'm not looking forward to removing all that junk on the inner fenders. Everyone says that it looks worse then it is but I don't know. That will definitely be a long weekend project.
It's not that bad.
Head up to the shop on a saturday and we'll BBQ and get some work done!
- Bronco Broker
Thanks man. I'm going to take you up on that offer.
I've had a few front clips apart and it's really not as bad as you would expect. Just go for it!
- Bronco Broker
Is anyone running a carbon or fiberglass dash? I decided to remove the dash this weekend on the four door. Speaking to John at Speed Unlimited we decided that it would be best to run a fiberglass dash and run the cage as close to the A Pilars and the firewall so away goes the oem dash.
I'm going the Fiberwerx's route:
Beard Ultra Pros are all in. My four seater is ready for a cage:
Saweeeet! Get this thing rollin Chris!
Order up the Fiberwerx center, and we can ask tio vic to pick it up for you Chris.... grab it at the 500!
nice build!
Where are the updates Chris???? Mark at Southwest can build a Bronco in two weeks... whats your hold up? I'll be waiting for ya!
Any chance you have a couple pictures of the roof intersection?BajaBronco13 wrote:Here is a picture of the floor section showing the merge between the original Ford F350 front crew cab section and the rear grafted Bronco section:
- Bronco Broker
- Bronco Broker
Not much going on with the four door Philo other then picking up some Walker Evans wheels:
Nice to see Bertha is still moving along though.
Yikes! LOL..... Yeah, that looks about like what I remembered. It's been about 10 years since the one that I looked at.
you don't want to look at the section lines on these things - they are FUGLY from what I have seen. The 70's stuff they did in the ford factory (crew cabs like mine were made from 2 cabs pulled from the assembly line) look MUUUUCH better.
Go look around in a Limo shop and that stuff won't scare you so much.
Centruion/Magnum & a imo shop = same thing pretty much. SCARY what people build and drive around in every day. ESPECIALLY stull like limos that are so common
Keep dreaming! We talked about this truck a bit while at the 500 this weekend but as usual he hasn't done anything but look at it. Much like one of my builds...D1cker1 wrote:Updates?
- Bronco Broker
ha ha ha shut your pie hole Steve and get at least one of your trucks running. At least I have my 86 that I can go out and play in.ChaseTruck754 wrote:Keep dreaming! We talked about this truck a bit while at the 500 this weekend but as usual he hasn't done anything but look at it. Much like one of my builds...D1cker1 wrote:Updates?
