getting an easy out.....out
Re: getting an easy out.....out
extensive ain't nothin if you can't drive it...
Well make sure you set all the EFI stuff aside for me.bajascott wrote:haha so im back to the origional plan of getting rid of ALL computer controlled componants on this.
thanks for all the advice and help on this .
this is why this website is so cool!!
SteveG wrote:A note on easy-outs. If the broken bolt isn't turning then you need to stop cranking on the easy-out before it breaks. Drill it out to a larger size and keep doing this until it relieves the tension between the bolt and whatever it's threaded in. Yeah, I know, too little too late, but maybe it'll help someone else.
Instead of welding a nut to it, try welding a washer to the broken bolt then weld a nut to the washer.bajascott wrote:just tried it, and the welds break out at the easy out. haha this sucks
He just might need to get access! Maybe you could rent one, Scott?shockseals.com wrote:He has no torch access...
Also get a set of left hand drill bits to go with your set of ez outs. Sometimes the broken bolt comes right out with the drilling action.
Use blaster or solvent then try the the reverse drill. Heat sometimes works. Consider drilling all the way out to the threads then try a tap to clean out the threads.
I would never use an Ezout again. Always had a bad experience with them.
Paul
Paul
