1995 F-150 Build
Re: 1995 F-150 Build
The internal sleeve portions on yours look way less rusty than the ones I've pulled apart.
Becks_Bronco
Post by Becks_Bronco »
Nice man! You drive it yet???
ChaseTruck754 wrote: ↑
Mon Oct 19, 2020 3:23 pm
Same, the ones I have taken out took much persuasion with a BFH just to get the nuts out of them.
S00TLYFE
Bronco Info: IT RAPTOR NOW
Post by S00TLYFE »
Becks_Bronco wrote: ↑
Tue Oct 20, 2020 12:53 pm
no i still dont have seats lol
S00TLYFE
Post by S00TLYFE »
yeah man i was really surpised with how easily these came apart
I think the ease in which they came apart is due to how clean they were. I've tried the puller setup like you made with no luck. Had buddies who have used it on 70's stuff and had the puller work. Not me. Out of the handfull of 70's stuff I've done and the 3 broncos ('86, '87 & 96) all were rusty and a major PitA that put up a good fight. I've ended up drilling some, sawzalling others, chiselling one, etc.
S00TLYFE
Post by S00TLYFE »
Tue Oct 20, 2020 3:31 pm
thats what andy had to do with his as well actually haha
Yep! Sawzall and a 30 pack of silver bullets!! Lol
I did the ones on my crew cab a while back. The 4 on the cab came out like yours, but the core support bushings on the battery side were a nightmare. I'm sure it took me longer to do the core support bushings than the body bushings. Great looking truck. I bet you're itching to drive it.
S00TLYFE
Post by S00TLYFE »
hobbyturnedobsession wrote: ↑
Wed Oct 21, 2020 6:32 am
thanks man! and yeah i am it has been awhile since ive driven it, my new seats should be here today though so hopefully that means i can adapt the mounts and get them installed by the end of the weekend
S00TLYFE
Post by S00TLYFE »
also yeah, i think the core support ones were the worst to me also, i removed the fenderwells, and needed a 1/2" impact/breaker bar and a 48" pry bar to lift them enough to get the new bushings in, so worth it though, my doors close like a brand new truck now and i bet the truck will feel a lot more firm while driving now
S00TLYFE wrote: ↑
Wed Oct 21, 2020 11:45 am
I hear you. The driver rear had no form of a body mount left. my cab lines back up with the body lines of the fenders hahah. Did you go with rubber or poly? I did poly and they don't make noise, but the suspension bushings i did do some.
S00TLYFE
Post by S00TLYFE »
Wed Oct 21, 2020 2:37 pm
S00TLYFE wrote: ↑
i ended up going with the poly one, ive used their bushings on every other vehicle ive owned and had great results, personally havent noticed the noise either but i figure especially with this thing is its an offroad truck, its going to make all kinds of noise
S00TLYFE wrote: ↑
Thu Oct 22, 2020 9:11 am
S00TLYFE wrote: ↑
I agree with you there. They hold up better than the rubber ones. Some have issues with the sound and the ride / vibration but I didn't notice anything different.
S00TLYFE
Post by S00TLYFE »
new seats finally showed up yesterday, really stoked at the color match to the factory ford gray and the cushion is really nice too. If youre in the market for seats give these guys a call, this is Hunter Safety Products which is the Beard family, they just cant use the name anymore because they sold it to whoever bought Beard.
[/img]
S00TLYFE
Post by S00TLYFE »
I ended up purchasing the solo seat mounting kit to adapt the seats to my stock sliders, one thing that was a concern was head clearance especially once I cage the truck (I'm 6'5), so Andy was nice enough to help me cut down the upper slider and weld on the mounts, which should buy me 2-3" of head clearance. Cleaned up the sliders and hit them with a couple coats of spray paint. They look ok other than the front mount part which seemed to have run because of the angle. Tried cleaning it up and repainted it a few times and it got a little better but ultimately just decided to say screw it and send it.
These are done now (and look good), for for those other tall guys out there, you should be able to flip the mounts upside down so the bolt holes on the brackets like these from Solo point down vs. up. As long as the bottom of the seat is still up 2" or more from the cross members on the sliders you should be good
S00TLYFE
Post by S00TLYFE »
Mon Oct 26, 2020 11:42 am
thanks for the heads up Steve, i had initially considered that but Andy had done this already and offered to help, plus gave me an excuse to get out of the house and have some guy time haha...but definitely good to know for the future.
ChaseTruck754 wrote:These are done now (and look good), for for those other tall guys out there, you should be able to flip the mounts upside down so the bolt holes on the brackets like these from Solo point down vs. up. As long as the bottom of the seat is still up 2" or more from the cross members on the sliders you should be good
Tried that the first time around. The bottom of the seat would get eaten up on the slider when moved forward and back.
Got it. I've always made my own and flipped them down often. I haven't used the solo ones before so they must be a bit different dimensionally
