D1cker1 93 Build "The Croc"
Re: D1cker1 93 Build "The Croc"
D1cker1 wrote:The front is down right sexy.... Roll cage, steering, skid plate wider beams.
Loosing 4x is not an option
That's the bumper I have on my bronco.. that f150 was sexy until the owner let his drive it... now it doesn't exist...
Oh no.. The lady won't drive mine..
Integrity, Money, Relevance
1amD1cker1@gmail.com
Replaced the passenger door latch cable.
Replaced rubber bushings inside window motor..... Only took a year to replaced .. Lol
Thanks Tcm Glx for your expertise
D1cker1 wrote:Replaced the passenger door latch cable.
Passengers can now let themselves out!!!
loganb
Bronco Info: 96 xlt
Post by loganb »
kinda random, but you drove right behind me and my black pearl today at my work. plaza de la paz going towards rock and road cyclery
loganb wrote:kinda random, but you drove right behind me and my black pearl today at my work. plaza de la paz going towards rock and road cyclery
Hey Logan..should have came and said. Hello. I saw the black fsb and wondered if it was robertcrav..
Good to see another local GFB'er
Tchau
Broncodawg
Post by Broncodawg »
Are you still going to run around and let your dates out, or tell them "the doors fixed, let yourself out." Haha!
Only the ladies.. I open the door for Greg... (Jealous)
Potato chip rotor..
What a horrible day.. Still working
Brake drag?
Lots of brake Drag....
The Brake pad was completely gone.. I should have noticed something was up when my "Brake Light" indicator was on
1.I purchased new Rotors and pads..
2. Went to install them and i cannot get the hub off without a special tool
3. Purchase the tool....
4. Wrong tool
5.Remove Hubs
6. Brake caliper is completely extended and will not compress
7. Purchase New Caliper"VatoZone" $40
8. passenger Side Inner nut will not come off at all... It seems Cross threaded
9. Start on driver side.... 1hr later Finish driver side
Punched out old studs.. I have no idea how anyone used the old ones (10) $20
Oct 6
Cut off Old Rotor with a Grinder. $10
Old hub Still will not come off
Picked up spindles from BajaBroncos13"thanks"
Used a ton of Profanity F&*(*) etc...
Bronco is still down..
Anyone want to try getting this thing out.. be my guest
Pre Conclusion... Next time I'll pay someone to do this shit.. I've wasted 2 days of my time,energy,training,and sanity
Im ready to drop the CROC and go
Been in the same position, when a customer Bronco had the hub nuts WELDED to the spindle.
Apparently, they kept coming loose, because they left off the washer between the nuts. I smashed off what
was left of the rotor and the rotor bell, ground down a couple of wrenches and with careful use of the grinder, managed to undo the spindle bolts and
the spindle finally came off after 4 hours of swearing and sweating in 100F heat. A good used hub & brgs, spindle, a new rotor and pads later, it was going again.
economig
Post by economig »
Just trying to help but a little confused where you're stuck in the process.
Stuck separating rotor/hub or still trying to remove hub assembly from spindle? It's 0500 :)
Im stuck separating the rotor from the hub...
So i moved onto separating the spindle , but now i will be going back to the hub/rotor assemble.
You need to press the studs off with a press then press the studs back on with a press. The hub must be removed to do this.
You can pound the studs off with a hammer... you don't even need that much striking force.. they'll pop right out.
Tried pounding them out..
They didn't budge...
Croc is back in operating form..
Abs sensor cracked
Pb bolt blaster, and wd-40 is your friend!
Use an old lug nut threaded with some of the nut over the stud and smack the nut so the stud doesn't mushroom.
I have the new studs in already.. I will remember next time.. If I upgrade to 5/8 studs
