Gear ratios
Re: What gears?
Does that chart take into account that he has a c6 trans?
Re: What gears?
Merging with an existing gear ratio thread.
Re: Gear ratios
Not shure what gears his trans has, he could call Mogie, culhane or tranny mike. they would know off the top of their heads. Figured the chart might help though.
drewbee88
Re: Gear ratios
Post by drewbee88 »
This is what I have used in the past, great for figuring out what you will run on highway, great tool http://www.grimmjeeper.com/gears.html
Phoenix0783
Re: Gear ratios
Post by Phoenix0783 »
4.88s might be be a bit low for a non-overdrive transmission.
Totti
Bronco Info: 89 Bronco one piece front end and rear panels, coilovers..Its still a work in process
Re: Gear ratios
Post by Totti »
Phoenix0783 wrote:4.88s might be be a bit low for a non-overdrive transmission.
Low?..or Hi??
Re: Gear ratios
Low?..or Hi??
Both... Numerical high gears are low ...
With 35s, 4.88s, bw1356 and a C6, the engine would be turning 3465 rpm at 70 mph
With 35s, 4.88s, bw1356 and a E4OD, the engine would be turning 2328 rpm at 70 mph
Totti
Re: Gear ratios
Post by Totti »
robertcrav wrote:
Low?..or Hi??
Thanks..well Ill see in a couple of week how it does first in the road and then in the San Felipe desert..
