RMC's el hefe build.
Re: RMC's el hefe build.
Got it out and down easy money. As luck would have it my brother pulled up after I had it slung just prior to lifting. I have a bunch of machinery slings and shackles from work. Anyway perfectly balanced pick and drove out from under it, eased it down and rolled it right up the driveway.
That is cool when a plan comes together!
It's pretty rare at best for me at least lol
Finally back at this thing, going to grab the material to finish off the rear upper cage and order my rear bench seat tomarrow, made these tonight after fixing this dudes shock mount. This guy had an east coast toyota truck that lost an upper rear shock mount so I chopped a bolt head off and stuck it to the old mount location so time was limited this evening. Some progress is better than no progress I say. Anywho...b pillar base reinforcement plate.
Center bar fit up, working on the 4 diagonals that will meet in the rear section center.
Tanner287
Post by Tanner287 »
Looks good !!
Bitchen!! Looks like it all fits nice and tight.
Got a little time on it this evening.
Looking good Rob!
Thank you. Today I'm planning on removing the top, taking the cage out and top welding all the tubes. I want it done before koh.
That'll be awesome. Are you running 4 points?
Yes front and rear, but I will keep factory also. I think I have to to avoid a ticket on the fwy right?
Good thinking.
Rmc wrote:Yes front and rear, but I will keep factory also. I think I have to to avoid a ticket on the fwy right?
If the belts you buy are DOT approved... You don't need to.
You can't get dot approved 4 points can you?
Schrothe makes stuff I used in the euro car days. I'll look at more options.....
I was unaware there were dot approved for 4 points, I just remembered the ticket I was threatened with in my vw street racer so I figured just in case I should leave them. I was just going to put crow's in it.
Thank you Andy. I'm going to look into this more. I just remembered that cop telling me " this year came with shoulder a harness and I didn't see one" so if I can find a place to get these I will definately make an effort. Good looking out.
So I got this thing removed today, was pretty easy actually. On the floor it looks like an overgrown rhino cage.
