95 F150 4x4 " RagnFRD"
- Bronco Info: 95 F150 4x4 only has a 6in lift soon getting some solo Motorsports radius arms and
Re: 95 F150 4x4 " RagnFRD"
Picked up some 12" racerunners yesterday
- uploadfromtaptalk1378236711083.jpg (78.39 KiB) Viewed 1151 times
We are working on extending my axles then Making the coil buckets now that i got my coilovers
The coils are 600/700 that's probably to rough what do you guys think
Try em you never know. Id say probably but hell youve got em try em out.
Re: 95 F150 4x4
I believe there way too stiff, I'm thinking 350 over 400 range. But I ran 400 over 500 till I got what I needed for mine. Run them and see.
My dad finished up the extensions I thought they came out really good
- uploadfromtaptalk1379266239868.jpg (46.32 KiB) Viewed 1101 times
Finished the passenger beam gonna work on the drivers side tomorrow then gonna plate them
- uploadfromtaptalk1379381718588.jpg (53.12 KiB) Viewed 1074 times
Re: 95 F150 4x4
Looks very nice.
Got the plating done on the passenger beam the welds came out nice
- uploadfromtaptalk1379553510828.jpg (23.9 KiB) Viewed 1038 times
- uploadfromtaptalk1379553497900.jpg (45.95 KiB) Viewed 1038 times
- uploadfromtaptalk1379553487533.jpg (67.85 KiB) Viewed 1038 times
Re: 95 F150 4x4
How thick of plate is that? Looks like 1/4 inch. Definatly strong.
Yeah used 1/4 just to be sure it holds good haha
Finished the passenger beam and the radius arms since we cut before the hole we had to adjust the radius arm a bit haven't worked on the truck my dad accidently smashed his thumb working so can't get any updates going
- uploadfromtaptalk1380771120784.jpg (61.33 KiB) Viewed 1026 times
- uploadfromtaptalk1380771109813.jpg (67.44 KiB) Viewed 1026 times
- uploadfromtaptalk1380771101069.jpg (61.72 KiB) Viewed 1026 times
Finished the driver beam just need a couple of adjustments next is the engine cage so I'm picking up some dom tubing this week I did pick up some glass yesterday guy didn't know who made them but they were in good condition so I didn't care I mocked them up I just need to take the inner fender off
- uploadfromtaptalk1384139989907.jpg (135.89 KiB) Viewed 977 times
- uploadfromtaptalk1384139968352.jpg (24.03 KiB) Viewed 977 times
- uploadfromtaptalk1384139956169.jpg (29.01 KiB) Viewed 977 times
Re: 95 F150 4x4
This thing has come along way since you started. Looking good man.
Thanks man my dad and I hope to finish the front at least by the end of the year
Looks good. The beams look strong.
My dad and I finally got some time to work on the truck we started to make the plates for the frame. And hopefully today we will start on the engine cage
- uploadfromtaptalk1390151130423.jpg (118.68 KiB) Viewed 902 times
Finally had time to work on the truck some more this month We ran into some trouble trying to bend some pipe and couldnt do it right on my harbor freight bender luckly my buddy works at a muffler shop so he did it for us I finally welded the plate to the frame and we finished one side of the engine cage
- uploadfromtaptalk1394052202493.jpg (120.82 KiB) Viewed 831 times
- uploadfromtaptalk1394052172768.jpg (128.36 KiB) Viewed 831 times
I mocked the cross over bar today going to weld it all tomorrow
- uploadfromtaptalk1394419667576.jpg (139.78 KiB) Viewed 797 times
- uploadfromtaptalk1394419624734.jpg (116.09 KiB) Viewed 797 times
- uploadfromtaptalk1394419605810.jpg (130.22 KiB) Viewed 797 times
Got a lot done these past months it's coming down to the last bits mocking up the glass and getting it ready for paint[attachment=-1]uploadfromtaptalk1405203342166.jpg[/attachment][attachment=-1]uploadfromtaptalk1405203358975.jpg[/attachment][attachment=-1]uploadfromtaptalk1405203375077.jpg[/attachment] [attachment=-1]uploadfromtaptalk1405203317420.jpg[/attachment]
- uploadfromtaptalk1405203375077.jpg (252.7 KiB) Viewed 700 times
- uploadfromtaptalk1405203358975.jpg (225.57 KiB) Viewed 700 times
- uploadfromtaptalk1405203342166.jpg (235.45 KiB) Viewed 700 times
- uploadfromtaptalk1405203317420.jpg (217.76 KiB) Viewed 700 times
