- baja-chris
Re: Stroker motor talk!-Threads merged
OK, I know the intake is not exactly the same, the 351 is about 1/4" wider but weight wise 302 and 351 aluminum intakes are about the same. BTW, how come there is no edit feature on this site?
deck height is 1.3" taller in the 351, and from what I've found that is worth 25-30lbs itself, the extra 55-60lbs is in the rotating assembly from what I've read
The mains on the cranks are much larger on the 351. Block has much more meat in the crank area. Crank itself is 10? pounds heavier than a 302. Everything in the bottom end is larger and it add's up.
It was taken away after abuse by some.baja-chris wrote:BTW, how come there is no edit feature on this site?
- Bronco Info: 1987 F150, 351W/418 Stroker, E4OD, F250 1356 W/fixed yokes, Sterling 10.25, D50 TTB 4" over
The Injectors from the 460 are 24#. There are 2 different model injectors though. The early ones have 1 hole in the bottom for fuel to spray from and the 2nd gen have 4 holes and are suppose to atomise (sp) the fuel better.
I would also be interested in seeing HP and TQ #'s from the strokers. I purchased a used 418 stroker with stock heads, intake, TB and exhaust manifolds. It was in a bronco that was wrecked by the guys daughter who was not suppose to be driving it.
It was mass air and was tuned on a chassis Dyno. It had a C6, np205, 9" and 35's.
To the wheels it had 257hp and 344TQ. I will try to find the paperwork to see what rpm those were at. The TQ was pretty flat all the way through.
Here is a quick and dirty injector calculator based on hp goal
http://fuelinjectorclinic.com/flow-calculator
460 Injectors are good for 370HP at %90 duty cycle according to that chart.
- baja-chris
Ford crate engine, 351 stroker built to 460 (bored and stroked), 575hp, 575 tq.big-d wrote:I would also be interested in seeing HP and TQ #'s from the strokers. I purchased a used 418 stroker with stock heads, intake, TB and exhaust manifolds. It was in a bronco that was wrecked by the guys daughter who was not suppose to be driving it.
Not a stroker but a nicely built roller 351 just for a ballpark TQ and HP.
Before tune
After tune
Before tune
After tune
[quote="RyanDS650X"]Not a stroker but a nicely built roller 351 just for a ballpark TQ and HP.
Do you have any details on that engine?
The first video has the mods listed in the intro.
Is a MAF conversion CA smogable? If its technically not is it something they would get hung up on?
Yes, as long as you bring it up to the complete specs of the model yr the MAF parts came fromcs_drums wrote:Is a MAF conversion CA smogable? If its technically not is it something they would get hung up on?
You poor cali guys and you silly smog rules... That has to frustrating as hell.
Looks like great info.
efi upgrade info . full artical Muscle mustang & fast fords 10/13 page 70
http://www.promracing.com/pro-m-efi-eng ... ystem.html
