95 F150 4x4 " RagnFRD"
JA_gonzalez
- Bronco Info: 95 F150 4x4 only has a 6in lift soon getting some solo Motorsports radius arms and
What's up guys so I finally got to building my truck my dad bought her in 95 then gave it to me my plans were to put a d60 under the front and just rush through the mud but my friends invited me to the desert and when I took her out I fell in love with the speed so now I plan on buying some c&t beams extended radius arms and some coil overs
- uploadfromtaptalk1374180247121.jpg (126.58 KiB) Viewed 3320 times
JA_gonzalez
Re: 95 F150 4x4 " RagnFRD"
The first thing me and my dad built was the front bumper wanted to change it up and build something a little different
- uploadfromtaptalk1374181841815.jpg (62.97 KiB) Viewed 3317 times
- uploadfromtaptalk1374181792697.jpg (139.8 KiB) Viewed 3317 times
- uploadfromtaptalk1374181775309.jpg (53.85 KiB) Viewed 3317 times
- uploadfromtaptalk1374181728490.jpg (52.91 KiB) Viewed 3317 times
- ESHALLBETTER
Re: 95 F150 4x4
Cool, I love to hear a "Saved the TTB at the last second" story. Keep the pics coming.
Re: 95 F150 4x4
Same here. Keep the pics comming. Long live the ttb!
- steve-oh
- Bronco Info: 93 xlt,5.0 caged, extended beams work in progress
Re: 95 F150 4x4
Truck looks familiar
JA_gonzalez
I've driven it since high school except the last 2 years since I needed a daily driver that didn't kill my pay check haha
JA_gonzalez
Finally had time to finish The bumper all it needs is paint
- uploadfromtaptalk1375840128608.jpg (55.82 KiB) Viewed 3182 times
- uploadfromtaptalk1375840118388.jpg (58.47 KiB) Viewed 3182 times
JA_gonzalez
Also I picked these radius arms up next me and my dad are gonna design some coil buckets similar to southwest performance and I'm looking for some 14" coilovers
- uploadfromtaptalk1375840153436.jpg (36.01 KiB) Viewed 3182 times
- funinthesun95
Re: 95 F150 4x4
love the ttb f150
are you keeping the beams stock width?
JA_gonzalez
Yeah for now I just want to get it running since it's been in my back yard for a while
- funinthesun95
Re: 95 F150 4x4
got ya.....with the drop downs you can always add the coilover set up and change the beams later to Cut and Turn
looks like you have 4 iinch lift drop downs...
Just be careful on upper shock mount location
or put the coil springs back on with the new raduis arms.....and have fun
JA_gonzalez
Yeah that's what I got the coil over mount is right on top of the new radius arms but I still don't know if I should just run 12" or 14" I'm thinking which ever I find a good deal on
- funinthesun95
Re: 95 F150 4x4
12 or 14 will work fine.....so yes best deal and go
my 2 cents
my 2 cents
What if they are priced the same?funinthesun95 wrote:12 or 14 will work fine.....so yes best deal and go
my 2 cents
JA_gonzalez
Probably going to pick up some 14" Foa coilovers from a buddy just to get this thing started my dad finished making the radius arm mounts yesterday once I get the Coilover we are going to make the Coilover buckets
- uploadfromtaptalk1376432236755.jpg (62.05 KiB) Viewed 3080 times
- uploadfromtaptalk1376432180268.jpg (56.63 KiB) Viewed 3080 times
JA_gonzalez
Finished product both of them mounting them tomorrow
- uploadfromtaptalk1376531167775.jpg (57.37 KiB) Viewed 3048 times
- 93Broncobuff
Re: 95 F150 4x4
beautiful.... very nice work man!
JA_gonzalez
Thanks man I was surprised how good they came out
JA_gonzalez
So a couple years ago when I put the 35s on I believe it cause my frame to cracked right by the power steering we welded the cracked and we are going to plate it also but my frame seems to look bent inward by the stock radius arm bracket so now when I was mounting my new radius arm brackets they are bent inward what do you guys recommend we are planning on trying to pull it out but other than that really don't know what to do
Re: 95 F150 4x4
Sounds like that side of the frame twisted, an auto body collision place may be able to straighten it with a frame rack and a porta power, hard to say. It really depends on how bent it is. After it straightened you will want to reinforce it well though or it will bend right back.
