Coil [Bucket] Spring Oprions???
Re: Coil Spring Selection???
mdlane72 wrote:What I am trying to understand is why buy a custom coil spring bucket?? Why not just simply take off the bucket-- clean or sandblast-- modify it to your choosing and then re-install with a gr8 bolt? Seems to me that you have to remove the factory bucket anyway-- and if you are at this level of suspension mod-- I am hoping you have a welder and can operate it.
See reply here: http://www.gofastbroncos.com/forum/view ... 7790#p7790
mdlane72 wrote:Second-- is there a reason that when the inner fenders are gone you can't run a shock behind the coil? I just like the looks of it better for some odd reason.
Nope. No reason. Lots of TTB/TIB trucks are built this way.
mdlane72 wrote:Second-- coming from an Early Bronco background modifiying the steering joints is totally normal- whether that be a GM 1-ton design to a rod end-- do people with the FSB do this mod or are the bronco/f150 ends perfectly fine. What about putting the joints on top of the knuckles for more clearance, and decreased working angles.
Isn't that two "seconds"?
See reply here: http://www.gofastbroncos.com/forum/view ... 7792#p7792
mdlane72 wrote:What about putting the joints on top of the knuckles for more clearance, and decreased working angles.
I did this on Big Bertha when it had drop brackets so I didn't have to have a drop pitman arm. After reaming the opposite side of the spindle there is not enough material for a taper to work correctly. I had to tighten the outer tie rod constantly and ended up destroying the stock spindles.
