Running the new Jamar Calipers front and rear. One of the best Calipers ive seen so far. Not sure as for hubs. Probably run the stock one for now and stock performance rotor and just the Jamar caliper up front. Theres nothing wrong with the stock hub or rotorscs_drums wrote:What calipers are you running? What hubs, rotors and calipers are going up front?
Full Build Bronco 550HP
- Dan88Rigid
- Bronco Info: Full build by Jason Rivera from Race Truck Factory.
Re: Full Build Bronco LS1
Rigid Industries - LED Lighting http://www.rigidindustries.com/
JAMAR Brakes http://www.jamarperformance.com/
Artec Industries http://www.artecindustries.com/
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Jamars, a step above CNC's, somewhere below Wilwoods, Brembos and Performance frictions.......
- Dan88Rigid
I beg to differ you probably havent checked out or seen there new racing program and products. Householder Motorsports, Mikey Childress, Green Army, Letner Racing, Cops Racing, and Chase Motorsports all run them and finish in the top 5 in just about every race with no problems should show the quality and how good they are.BDKW1 wrote:Jamars, a step above CNC's, somewhere below Wilwoods, Brembos and Performance frictions.......
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
I have seen them. They are slightly better than CNC's. There is nothing in there desigh which points to any FEA testing or other cool research and development. They do not have dust seals like higher end Wilwoods or other trick features found on other top name calipers. Tell Me how they are better. Show Me deflection graphs under pressure. Show Me braking torque figures. Until I see those with better results than other calipers I will not be impressed. Where is NTSQD when you need brake analysis......
CNC's are about the most stone age calipers out there. It was basically, mill away everything that doesn't fit inside the rim and call it good. There is no engineering in them at all. They just didn't break in half so they became the off-road standard. Monkey see, monkey do. Which is what I'm seeing from the Jamar guys. lots of good talk, little in the way of facts.
How is the price comparison?
- Firetwig
- Bronco Info: 1978 Ford Bronco 1996 Ford Bronco
Loving the LS build man.
- Dan88Rigid
Motor, Th400, and NP205 transfer case being installed.
- photo(13).JPG (207.13 KiB) Viewed 3890 times
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
- Dan88Rigid
Thanks i hope to have it ready for San Felipe 250 but its gonna be close.
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
- Dan88Rigid
Re: Full Build Bronco 550HP
The motor is off to the builder. Expecting to get 550-580HP out of the motor on pump gas.
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
Do you have any pictures of the interior?
- Dan88Rigid
As of right now i dont. Im on the road working so i will try and have the builder take some. The only thing installed is the dash for right now. Center console to be built soon.D1cker1 wrote:Do you have any pictures of the interior?
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
TubeWorks Rearends
TUFF STUFF Winches
Race Truck Factory
Alper Motorsports
Trek Armor
- Dan88Rigid
Mounting up some Rigid Lights!!!
- Dan88Rigid
(2) 30" Rigid E-series bars mounted.
- photo(3).JPG (145.11 KiB) Viewed 3561 times
You need to put some teeth between those light bars.
Hahaha that would be awesome!
- Dan88Rigid
I will get some white covers and outline the teeth on the covers.SteveG wrote:You need to put some teeth between those light bars.
- Tanner287
Hey is mcniel not sellin this rear glass anymore?? Or do you have to call to order it? I really like it just didnt see it on their website
Not on there website but still available. Just picked mine up a month ago
- Tanner287
How much wider is your rear end then stock? Just curious to see how the glass would fit my bronco since it seems like it fits your great. I'm 4" over each side in the rear plus 37s
