Joel's Bronco II
- DirtFiend602
- Bronco Info: 86' go faster
Re: Joel's Bronco II
I'll sure you can build yourself a pair of bumpcans Fab wizard lol
- Copykat
Got some headway with the rad arm mounts, and trans mount. Need to get some measurements where a few componets are located to get a better feel for the trans mount.
May have to go low tech when designing the coil buckets. Cardboard and sharpie. Once done in cardboard I can transfer it to CAD, and clean it up.
1987 BroncoII 4x4
- Copykat
Damnit. All these badass builds going on, are giving me the itch to get working on my Bronco.
1987 BroncoII 4x4
- Copykat
Just picked up 2 bushings for the trans crossmember, and 4 for the cage.
By the sounds of it my hyd bump stops are on the truck for delivery.
Cage tube is waiting to be picked up.
1987 BroncoII 4x4
- Copykat
Joel's Bronco II
Bushings for trans and cage.
- ImageUploadedByTapatalk1336613028.592457.jpg (48.3 KiB) Viewed 1868 times
1987 BroncoII 4x4
- Copykat
Time to clean up the individual parts and key them. Then it's ready to be broken out and cut.
1987 BroncoII 4x4
- Bronco Info: 1994 XLT, 351 6" lift 38" mudders
Very nice Joel. Having owned a bracket you designed and built, I know how well your truck built. Top notch man.
- Copykat
Nice to see you joined Ben!DamageIncNY wrote:Very nice Joel. Having owned a bracket you designed and built, I know how well your truck built. Top notch man.
1987 BroncoII 4x4
- Copykat
Got a rough model in place for the shocks and bumps.
With the 5.5" deaver coil I should be able to get 21" travel, that is if I can keep the joints from binding.
At the spring it's about 6" uptravel and 8" droop. This is with the 14" travel fox shocks in front of coil and I still have 1" on the bump.
1987 BroncoII 4x4
- Bronco Info: 1994 f150 bronco wannabe
So , are you moving the lower coil mount in on the beam, or moving the top out to meet the f150 coil mount, or have i missed it entirely.
Are the bushings polyurethane or delrin/acetal?
I'm sure they're probably poly but the pic makes um look like delrin.
Got it. I figured there wouldn't be a zerk on delrin, but maybe if it was the lower end, non impregnated stuff.
- Copykat
Joel's Bronco II
Originally they were not the ones I was after, but a buddy had 6 from a past project and wasn't planning to use them. Couple tweaks to my CAD model and they fit perfect.
1987 BroncoII 4x4
Hey if the price is right go at it. I'm always using what I come across that helps keep my budget low.
- Copykat
Joel's Bronco II
The only downside is that everyone seems to have bits and parts that I'm looking for when I don't have the cash.
1987 BroncoII 4x4
Agreed there, my problem always goes like this cash flow , but no time, or brillant vision and broke.Copykat wrote:The only downside is that everyone seems to have bits and parts that I'm looking for when I don't have the cash.
- Copykat
Joel's Bronco II
So I ordered my tube couple weeks back and had a buddy lined up to pick it up. My buddy called me saying he was at the shop but there was no one there and the compound was locked. Tried calling the machine shop and got no answer. So it will have to wait for another day. But what ticks me off was when I got a call from the shop the next day. I find out that the tube was left outside in the rain. So I got the shop to bring them in till I can line up a trailer again. Hope to get it this week sometime.
1987 BroncoII 4x4
