HTO'S BRONCO BUILD
Re: HTO'S BRONCO BUILD
Shoot man you'll have extended beams too! Thank you, Scott did an amazing job building them. I just asked a Shiza ton of questions and bolted them in.
Thank you Jeremy! I'm hopin to give it a run while were in Barstow!
Well I've got the hard stuff done now. The diff and axles and spindles are in but I didn't have any gas or wheel bearing grease so the hubs are coming back off. Will have it done tomorrow. Pics tomorrow as well.
Went to Barstow and back with 0 issues!
- 340743_2290638870174_1375070398_32030868_11861291_o.jpg (271.21 KiB) Viewed 1031 times
- bajascott
- My belly is my best friend
get that thing painted one color,its looking like rainbow brite!
glad everything worked out for you Randy, i made some adjustments to my measurements. you did a good job getting this back together
- SuperSixAxis
- Bronco Info: 1996 5.8, E4OD
That setup was boss status, great job Scott/Randy!
Thanks guys! Yes Scott I'm planning to have it wrapped! Hahah the rainbow bride I like it. No worries Scott I owe you a big thanks because if not for you it wouldn't have gone so well!
- Silverslk
Looks great!! MORE pics!!!
Ha thanks Andy! Get started on those extended beams! Ill post more when the alignment is done. Carly is taking it in for me tomorrow.
- Silverslk
Dont hold your breath. Those wont be on/done til next year.
HTO'S BRONCO BUILD
And next year is less than 25 days away.Silverslk wrote:Dont hold your breath. Those wont be on/done til next year.
philofab wrote:And next year is less than 25 days away.Silverslk wrote:Dont hold your breath. Those wont be on/done til next year.
That is Very True
Here is a few shots from this weekend. I mounted the drivers side fender well. I need to cut some rubber to fit in the gap between the fender well and the inner fender. I haven't done the passengers side yet but I will start that this week.
- Resampled_2011-12-11_15-22-56_770.jpg (133.8 KiB) Viewed 890 times
- Resampled_2011-12-11_15-22-45_857.jpg (205.41 KiB) Viewed 890 times
- DirtFiend602
- Bronco Info: 86' go faster
looks awesome!
Thank you! Also, I owe Philo a big thank you. I pulled the white vacuum line out of the black tubing and it was broken about an inch back. Fixed it and now it idles at 700 all day.
Well after selling off some parts I saved enough money to order a stock fiberglass from Perry. Really nice guy and I pick it up on Saturday. Also, greaslife hooked me up with a cool piece he built for the antenna so I don't have a stupid spring and a bumper were going to mount up on Saturday.
