HTO'S BRONCO BUILD
Re: HTO'S BRONCO BUILD
ready to box them up ups truck comes tomorrow eve and away they go!
Daannng!.. those look good Scott!.. Congrats on the getting rid of the drop down brackets, Randy!!
thanks andy!
hey Randy, the brown truck will be leaving 2 packages on mionday. and yes i used a kitty litter bucket to pack your hubs into!! haha and i threw in a stainless ss keychain
SuperSixAxis
Bronco Info: 1996 5.8, E4OD
Post by SuperSixAxis »
I am digging this Build HTO. The fact that you give so much info along the way is really motivating to a new builder!
Plus, those beams are AMAZING! I am looking forward to seeing this truck in person!
Thank you! These guys have helped me alot the last few years and I just want to return the favor. Scott is awesome. He can help out on top of building some spectacular parts.
So after the wedding I started pulling apart the front end and replacing the beams and brackets! Well the diff has some chunked spider gears so that gets fixed Monday. (Thank you Tony) here is a few shots of progress.
hobbyturnedobsession wrote:So after the wedding I started pulling apart the front end and replacing the beams and brackets! Well the diff has some chunked spider gears so that gets fixed Monday. (Thank you Tony) here is a few shots of progress.
No worries...... did you forget to insert pictures here.
Hahah sorry I was working on it, and my phone wont resize the picture so here we go!
here it is
SuperSixAxis
All eyes on this build Randy! No Pressure, LOL!
Lol I'm building this at a slower pace man, I've learned that I HATE doing things multiple times. The front end will receive new ball joints and tie rod ends and spindles. (New to me on the spindles). I had to clearance the passenger side beam bracket a little for the uniball cups, and that was pretty much it for the alterations. By the way thank you Steve (chasetruck) for the beam brackets and Scott who has answered all of my questions!
Right on Randy! Make Scott proud!
Haha thanks Brian! If I can keep up with you all then he can be proud!
What drop brackets did you take off, Randy? I have someone over here who might want them.
Getting work done Randy! Digging the beams man.
Thanks Chris! After Baja I knew that if I wanted to hang with all you fine gentlemen I needed to set the truck up clean. You all have inspired and directed me. Thank you guys.
Lookin good bro, when and where is the shake down run going to be?
I'm hoping this next weekend at the races!
Well I got some more stuff finished, once the front diff is rebuilt I can finish the re assembly.
Becks_Bronco
Post by Becks_Bronco »
Looking good!
