1997 f250 prerunner build
jimmyd
Post by jimmyd »
whats up guys. I am Wanna bronco from over on FSB (posted a greeting on intro page). I am going to start my build thread ( which at this point is about 75% done)
To start, its a 1997 F-250 HD extended cab short bed. It has a 460 and D50 TTB, and it had a 4" body lift. I was searching for an ext. cab short bed F150 4wd but could not find one in good shape.I have had this truck for about 1.5 years, and has been great. I sold my bronco, mainly because it sat in my garage for months on end, and in the hopes somebody would get some use out of it. I was able to raise a little capital to begin my build.
At first, i was going to do some sort of bolt on kit, like pro comp drop brackets. i searched for awhile and obviously found nothing, so decided from there i was going to build my own suspension. which eventually led to building a prerunner setup.
IMAG0083 (800x535).jpg (223.36 KiB) Viewed 4815 times
Last May i began gathering parts.
Cut and turned TTB from Solo motorsports,
2.5/12" Kings,
gas tank from a bronco,
progressive leaf pack,
Currie Heim joints
IMAG0014 (800x533).jpg (186.18 KiB) Viewed 4815 times
and some other stuff, like rear bumper is built, tire carrier pieces are all cut and or bent up and pretty much have the design worked out.
I broke the project up into two "phases", one where i took the bed off and used a chassis paint product and replaced some brackets in the rear, as well as stuffed a bronco gas tank in the rear. i had to make a 1.5" drop bracket to allow for fitment, but turned out pretty well. I'll try to get a better pic. i also took the dumb ass body lift off!
IMAG0079 (800x535).jpg (211.26 KiB) Viewed 4815 times
body lift  taken off
body lift taken off
IMAG0023 (800x533).jpg (169.5 KiB) Viewed 4815 times
jimmyd
Re: Go Fast ( presented in f250 HD)
Post by jimmyd »
I began "phase 2" thanksgiving weekend.
IMAG0008 (800x533).jpg (181.69 KiB) Viewed 4812 times
at this point i had most everything purchased or fabbed as far as it could be.
IMAG0074 (800x535).jpg (165.21 KiB) Viewed 4812 times
tranny x-member and radius arm mounts
IMAG0057 (800x533).jpg (179.31 KiB) Viewed 4812 times
everything torn out
everything torn out
IMAG0033 (800x533).jpg (194.39 KiB) Viewed 4812 times
no pics, but i had purchased a used set of coilovers off of race dezert, but was still in the infancy of coilover knowledge ( i am still only maybe a toddler at this point though!) they had a 350 over 400 spring rate, obviously not enough. i have sinced purchased a 600 eibach and 700 King, think that should do the trick.
Firetwig
Bronco Info: 1978 Ford Bronco 1996 Ford Bronco
Post by Firetwig »
Thank goodness no more 4inchs of body lift!
I have 600 + 700 coils for my truck as a starting point. We'll see. Do you still have the other coils?
jimmyd
Post by jimmyd »
i need to get some more pics of the front end , but i am pretty much done. really all i need to do is weld it all up.
everything painted with the chassis liner
IMAG0035 (533x800).jpg (193.65 KiB) Viewed 4804 times
IMAG0036 (800x533).jpg (225.04 KiB) Viewed 4804 times
another pick of the tranny x-member tied into the radius arm brackets
IMAG0066 (800x533).jpg (161.66 KiB) Viewed 4804 times
and not to make you guys jealous but the postman is bringing these guys next week
some of these
http://www.4wheelparts.com/Wheels/Rock- ... CW152-6181
with a few of these!!
http://www.4wheelparts.com/Tires/LT315- ... 4568390000
jimmyd
Post by jimmyd »
philofab wrote:I have 600 + 700 coils for my truck as a starting point. We'll see. Do you still have the other coils?
yeah, want to buy them?
Sweet! I really dig the f250extra cab shortbed. I'd suggest you keep your existing wheels. They are forged alcoas, much better than most stuff out there
jimmyd wrote:yeah, want to buy them?
Possibly. Name your price as they would work well on the Bronco I have.
tcm glx wrote:I'd suggest you keep your existing wheels. They are forged alcoas, much better than most stuff out there
X2. Those Generals will fit fine on your OE wheels. The forged Alcoas also fit the bore of the hub perfectly which makes them and the lug stud stronger.
jimmyd
Post by jimmyd »
yeah i hear ya, but something I've left out of this is whole thread is that i live just outside Kansas city (however I am from San Diego), there are some dunes about 5 hours from here, but the truck isn't going to see anyhting too extreme. my goal is to slowly build the truck up, and go more extreme. maybe get into the Texas desert races in a year or two. but for now this will work.
jimmyd
Post by jimmyd »
picture of rear bumper. need to cap the end, not sure what to do yet.
rear bumper, almost done
IMAG0080 (2) (800x533).jpg (151.8 KiB) Viewed 4729 times
IMAG0081 (2) (800x533).jpg (153.83 KiB) Viewed 4729 times
this is my battery box for my optima red top, i am mounting it uder the bed just in front of the passenger side rear tire.
battery box
battery box
IMAG0083 (2) (800x533).jpg (164.8 KiB) Viewed 4729 times
angle is weird so the gas tank looks really low, plus i have the front end up pretty high.
picture of the bronco gas tank
IMAG0082 (3) (800x533).jpg (158.66 KiB) Viewed 4729 times
smart phones are awesome but take terrible pictures
jimmyd
Post by jimmyd »
setting up coils, with temporary shock hoops
IMAG0075 (2) (800x533).jpg (199.33 KiB) Viewed 4728 times
front view
IMAG0076 (2) (800x533).jpg (195.68 KiB) Viewed 4728 times
radius arms, there not done yet, only tacked up.
IMAG0079 (2) (800x533).jpg (183.41 KiB) Viewed 4728 times
i'll stitch them up and when everything is done and looks good, pull it all off, weld it all up then add some dimple died plates.
jimmyd
Post by jimmyd »
how do i go about putting the coilover into the shock hoop and lower shock mount once its all done? the only thing i can think of is a coil compressor, which is less than ideal.
also, i need to RE-rebuild the coilover, seeing as i am pretty sure i did something wrong the first go around, can i charge the shock once its on the truck?
You should not need a coil compressor to install the coils onto the shocks. They shocks need to be charged at full extension, weather that be in or out of the truck.
jimmyd
Post by jimmyd »
got my new tires 35's
IMAG0097 (427x640).jpg (119.67 KiB) Viewed 4678 times
i am going to need fiberglass quicker than i thought
IMAG0101 (640x427).jpg (148.5 KiB) Viewed 4678 times
IMAG0102 (640x427).jpg (140.98 KiB) Viewed 4678 times
jimmyd
Post by jimmyd »
philofab wrote:You should not need a coil compressor to install the coils onto the shocks. They shocks need to be charged at full extension, weather that be in or out of the truck.
yeah, i don't know what i was thinking. i had tried fit them in there before, but i think i was doing it wrong. i got it now
Go back to the Alcoas, and you wont need the fiberglass, those wheels look pretty wide, and with a pretty high offset. That is likely causing that tire sticking out so much.
Firetwig
Post by Firetwig »
Or I'll take them off your hands...
campbbg
Bronco Info: 1993 Eddie
Post by campbbg »
I agree stick with the alcoas ...... but if not I'll take them off your hands
or if those 2 flake I'll take the alcoas - haha
