sorry for the delay, personal life got in the way a little bit. back to normal now.
regarding the pinion angle. its in, its done. always going to be a compromise. looks perfect at ride height. i will move the axle back and get a longer driveshaft to help lessen the pinion angle movement. pics to follow.
also worked on mounting the shocks. built some lower tabs, used ruffstuff upper tabs.
shocks are walker evans 14". had to change out the fitting on the reservoir hose from a straight fitting to a 90* fitting. I released the excess nitrogen pressure. which was different in each shock. Also there were different quantities of oil in them which I thought was weird. I'm going to see if I can get the specs from walker for oil quantity and depth of the reservoir piston before I add any nitrogen. I've never gone through a set of these before so this will be a learning experience for me.
on to the pics. finished up the shackles with the inner plate.
- 20190318_093350.jpg (159.5 KiB) Viewed 3856 times
- 20190318_103619.jpg (105.38 KiB) Viewed 3856 times
then I worked on the lower shock mounts
- 20190309_172729.jpg (123.4 KiB) Viewed 3856 times
- 20190309_172620.jpg (124.18 KiB) Viewed 3856 times
- 20190311_192546.jpg (120.56 KiB) Viewed 3856 times
- 20190311_192528.jpg (126.41 KiB) Viewed 3856 times
with the lower shock tabs I ended up grinding a lot more clearance into them so that nothing rubbed at full droop or under articulation. Hopefully they hold up. If not, I'll learn from it and make better ones.
@outdoorexplorationgear on Instagram, focused on Krustythebronco, building a towrig, creating a prerunner/rockcrawler business.
