1995 F-150 Build
S00TLYFE
Bronco Info: IT RAPTOR NOW
Re: 1995 F-150 Build
Post by S00TLYFE »
I guess pictures are back on, new picture bomb inbound
S00TLYFE
Post by S00TLYFE »
A couple picks from new years in Johnson Valley
S00TLYFE
Post by S00TLYFE »
Pictures of the truck with the short-lived shell that it had.
Got it tinted while I was working up north not too long ago.
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
This also happened yesterday, Solo Motorsports rear bumper to match the front. ImageImageImageImageImageImage
biggiek
Bronco Info: 92 Ford Bronco
Post by biggiek »
I do like that bumper. Do you feel like its worth the cost?
What is the cost?
S00TLYFE
Post by S00TLYFE »
ChaseTruck754 wrote:What is the cost?
They're pricey if you buy them done from Solo, around $700-800 i believe, you can also buy everything pre-cut and pre-bent and its about half that cost.
S00TLYFE
Post by S00TLYFE »
biggiek wrote:I do like that bumper. Do you feel like its worth the cost?
Yes, totally do believe so, especially if you buy the weld it yourself kit
That's not horrible - especially if they offer in a weld it yourself setup. Guys want bumpers for like $250 it seems & don't understand why they cost more. They hours spent in bending, cutting and welding add up super quick on them though. I know I had the better part of a full day building the simple rear for my tacoma
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
ChaseTruck754 wrote:That's not horrible - especially if they offer in a weld it yourself setup. Guys want bumpers for like $250 it seems & don't understand why they cost more. They hours spent in bending, cutting and welding add up super quick on them though. I know I had the better part of a full day building the simple rear for my tacoma
Totally agree Steve, and this thing was literally perfect, everything lined up exactly where it should have, the front I had to blow the holes out a size up on the frame with a step bit and that’s it.
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
Took the truck for a spin today after finally being home long enough to put it back together. Missed driving this thing.
Stan the Man
Bronco Info: 1996 Ford Bronco, trail ready/sand loving.
Post by Stan the Man »
I really like the look of that extended cab long bed. The only thing better would be a short bed. Time to call solo for that!
Stan the Man
Can you share some photos of your front bumper frame mounts? I believe it just ties into the factory ears and sway bar tabs?
zachwabbit
Post by zachwabbit »
It is a short bed! Haha that’s kinda funny though, everyone around here thinks my truck is a long bed too for some reason
Potato.
S00TLYFE
Post by S00TLYFE »
Stan the Man wrote:Can you share some photos of your front bumper frame mounts? I believe it just ties into the factory ears and sway bar tabs?
yes, it is 100% bolt on to the factory frame locations, no adapters, cutting etc necessary.
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
Coming soon!
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
Truck is getting 4.56s in the front (finally)
Desolate High-clearance Radius Arms, Desolate cut&turn beams with truss, uniball, and plate, Desolate Coilover Towers, bumps, straps, and the rear is getting an underbed shock setup with raptor take offs (Thanks Travis @ Solo)
1995 F-150 Build
Good looking parts! Tick tock...
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
Full hovercraft mode engaged.....
S00TLYFE
1995 F-150 Build
Post by S00TLYFE »
RyanDS650X wrote:Good looking parts! Tick tock...
Haha suspension will be done I just hope I have time to wire up my race radio by then finally
Only had it for like 2 years
