I recently bought a 95 project truck for my wife. It's got a 5.8 that the previous owner added an MSD ignition, Bearing kit, piston rings, Rod bearings, gasket, main bearings, timing chain, oil pump and water pump to. Very nice of him but it's slow and needs the topside updated.
I'm putting all new suspension from SOLO along with new wheels, tires and brakes but that's where my knowledge stops. I know almost nothing about these motors and need help understanding what can be done to make a nice daily with some ooomph. 350-400HP would be great.
I see kits from Edelbrock and Holley but all seem for carb trucks. Would i need something like the Edelbrock Total Power Package work by itself or is something additional needed?
Thanks and sorry it this is a dumb question, i'm still learning.
More powaaaaah from my 351w
Re: More powaaaaah from my 351w
Gonna be honest here, what do you WANT 350 - 400 HP for? DO you race this truck every day? Is it a daily driver? Do you have to do smog tests?
No, sir, what you NEED is more TORQUE, not horsepower. Seriously look at a 393 stroker kit, CARB approved aluminium heads, PORT MATCHED stock intake and use a roller block with a 87 - 91 Mustang factory roller cam and 1.7:1 rocker arms. Add good CARB approved headers and some form of off-road Y pipe and 3" single exhaust (fit the stock cat Y pipe only for smog tests). Them make sure you get it PROPERLY dyno tuned to maximise your combo. This will give you excellent torque, and better gas mileage (you wont have to lean on the gas pedal as much) for normal driving. Just my $0.02.
Yeah you’re absolutely right. Torque is much more important for me. Any idea if someone makes a kit with all the parts I need? I don’t want to have to become expert on these motors as I already support two race cars I own and have had to become to an expert on their systems.
Thanks for your reply!!!
There are several build on here to go from but no one make a “kit”. These motors are old tech and not many people building them.
The biggest restriction is the own style intake. Edelbrock makes a replacement but still a lot to be desired. Look at Shockseals recent stroker build, very well done smogable power
No problem.XLR8 wrote:Yeah you’re absolutely right. Torque is much more important for me. Any idea if someone makes a kit with all the parts I need? I don’t want to have to become expert on these motors as I already support two race cars I own and have had to become to an expert on their systems.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Thanks again for all the details. The bottom of mine was refreshed two years ago so was hoping for just top side work. Might drive it for 2019 with my new suspension and investigate motor swaps.
