1Hondalover wrote:You detail this in your RDZ ad Kris:
F350 double cardan front drive shaft so no vibes with hubs locked on highway
Can you elaborate just a bit? I get this and I'd like to implement soon for the exact same reason.
replace the T case yoke with one from a F350 with 1356 tcase ad get a NOS driveshaft from a F350 off ebay and install. Easy install and no vibe. There is a vibration TSB for all broncos that lists the yokes and part numbers for driveshafts and anybody who complained of vibration with hubs locked on highway.
"Driveline - Vibration/Noise at Highway Speeds
Article No.
97-13-22
06/23/97
^ NOISE/VIBRATION - WHEN DRIVING IN 4X2 MODE
WITH HUBS LOCKED - 4X4 MODELS
^ DRIVELINE - VIBRATION/NOISE - WHEN DRIVING IN
4X2 MODE WITH HUBS LOCKED - 4X4 MODELS
LIGHT TRUCK:
1987-96 BRONCO, F-150, F-250 LD
1987-97 F-250 HD
This TSB article is republished in its entirety to include 1996 and 1997 model year vehicles.
ISSUE:
A driveline vibration or noise may occur when driving a 4X4 truck at highway speeds in a 4X2 mode with the front drive hubs locked. This can occur if the driveline angle is incorrect.
ACTION:
Replace the front driveshaft with one that has a double cardan joint at the transfer case and a compatible companion flange for the transfer case."
