Bray's 96 Sleeper
DMbronco
Bronco Info: 96 XLT 351
Re: Bray's 96 Sleeper
Post by DMbronco »
DMbronco
Post by DMbronco »
DMbronco
Post by DMbronco »
DMbronco
Post by DMbronco »
De$ertBronco
Post by De$ertBronco »
:lol: JK! looks great brother!
DMbronco
Post by DMbronco »
haha, you aint lyin Josh! She is a glutton for attention, parts, gas and dollars!
DMbronco
Post by DMbronco »
HUGE thanks to the guys at Richer- especially Mike, who along with Eddie at Crown Performance, helped to figure out the puzzle of fittings and lines I needed to get the braking system right.
Big shout out to Josh for all of his expertise in all things Ford too- thank you for ALL the help brother.
Here's a shot of Mike's badass work (does not do it justice)
DMbronco
Post by DMbronco »
Battery in place, new rotors drilled out for 5/8" studs, fresh pads, seals and bearings.....
getting closer!
DMbronco
Post by DMbronco »
Steering in place.....
Bray's 96 Sleeper
What size are those fittings, on the side of the master cylinder?
DMbronco
Post by DMbronco »
Hey Andy, I will find out and get back to you when I talk with Mike....
Things are getting closer to completion...
cwrisley
Post by cwrisley »
Stoked for you brotha. This thing is turning out so rad.
Sent from my SM-G928V using Tapatalk
Bray's 96 Sleeper
[quote="DMbronco"]Hey Andy, I will find out and get back to you when I talk with Mike....
Thanks man !
DMbronco
Post by DMbronco »
Taylor snuck a shot this AM and sent my way.
First shot of the new stance (2" wider per side).
Stoked.
birdco85
Bronco Info: 95 5.8 MAF E4OD
Bray's 96 Sleeper
Post by birdco85 »
That is perfect!
apache41
Bronco Info: 1995 Ford Bronco Solo Coilover front, Deaver Rear with Solo under bed shock bracket and hanger relo
Post by apache41 »
Wow, very nice. I love the new King shocks. What spring rate are you going to run ?
DMbronco
Post by DMbronco »
birdco85 wrote:That is perfect!
Just like your wiring job Darren!!!! Hopefully I can get it as tidy as you left it the first time haha
DMbronco
Post by DMbronco »
apache41 wrote:Wow, very nice. I love the new King shocks. What spring rate are you going to run ?
Thanks Apache- here is the build sheet for the shocks- we'll see how they feel pretty soon
DMbronco
Post by DMbronco »
Looking good, I saw the tin work a few pages back and did not see any venting near the headers or in the top. Are you concerned that all that sheet metal will hold in all that heat we get under the hood? I have seen guys with paint peeling in the metal hood and browning of the underside of fiberglass.
Love the Bronco.
Sent from my SAMSUNG-SM-N900A using Tapatalk
