1989 Build
S00TLYFE
Bronco Info: IT RAPTOR NOW
Re: 1989 Build
Post by S00TLYFE »
Decided if the engine had to come out, I was gonna clean up the engine bay, so I pulled the core support too.
Victory
Started cleaning the engine bay, out came the power washer, wire wheels, and spray paint.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Those got placed backwards, but you get the idea.
I'm also deleting factory AC and running a vintage air unit as well as deleting non-essential components to get this thing as simple as possible. Gonna probably get the engine cage bolted in soon too.
1989 Build
Dang that's so clean! My favorite spray paint is rustoleum professional (it's in the silver can) much less fading in the weather/sun than just the regular paint.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Tchajagos wrote:Dang that's so clean! My favorite spray paint is rustoleum professional (it's in the silver can) much less fading in the weather/sun than just the regular paint.
I'll have to check that out, I bought a case of this flat black at Home Depot 12 cans for like 30 bucks.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Just dropped $ on a MAF conversion from
fiveology racing. Brian was awesome to deal with customer service wise, highly recommend talking to him if you're a speed density guy considering going MAF. To me the extra $ over junkyard parts was worth the lifetime warranty on all of his products.
carlover
Bronco Info: 95 lt 351w in progress
Re: 1989 Build
Post by carlover »
im looking into a MAF conversion too, how hard was this to do?
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Haven't done it yet, you have to basically swap the pcm and re pin 8 wires in the harness, which was easy to completely pull for me because I have the engine and the front end off of my bronco right now. With a little patience it should be pretty easy.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Took the time and when ahead and did the inside of the fenders and the hood, firewall etc. while I was at it. Figured might as well while it was out and it went a long way to improving the look.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Got the engine set back in and everything underneath the truck bolted up. Still working on the wiring but out of town work and the weather when I am actually home has really slowed me down on that. Finally seeing the light at the end of the tunnel though, can't wait to finally drive this thing.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
With the MAF Swap kit I ordered from Fiveology Racing, I got a new injector harness with a few other connectors, so I decided to de-pin and re wrap the old harness to clean up the engine bay and make future diagnostics easier.
Below are the Before/Afters of what the harness looked like without the injectors, O2 Sensor, HVAC, and a few other things that the truck will no longer be needing. I wish that OEM Ford Connectors weren't so expensive I would have replaced all of those as well.
THEJESUS
Bronco Info: 1992 BRONCO XLT
Re: 1989 Build
Post by THEJESUS »
That wire Job looks clean! I been looking into that fiveology kit wondering if its worth the trouble. Do you see that big of a difference?
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
THEJESUS wrote:That wire Job looks clean! I been looking into that fiveology kit wondering if its worth the trouble. Do you see that big of a difference?
I haven't been able to finish it yet but for
Like $600 and only having to REALLY re pin 12 wires I think it's worth the drivability and increased fuel economy. Plus it responds to engine modifications much better.
THEJESUS
Re: 1989 Build
Post by THEJESUS »
gotcha! I mean fuel economy alone will help im getting around 6-8 mpg haha! Ill have to look into it a little more.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
THEJESUS wrote:gotcha! I mean fuel economy alone will help im getting around 6-8 mpg haha! Ill have to look into it a little more.
haha holy shit man i dont think im doing that bad and i dont even have overdrive!
THEJESUS
Re: 1989 Build
Post by THEJESUS »
haha its horrible! I don't know whats causing it to get such bad MPG but yea I calculated it and im around 6-8. Not fun at all!
Re: 1989 Build
Going off on a tangent here so sorry, but Jesus - did you calibrate your speedo when you did the lift & put bigger tires on? If I remember right you fixed a lift that was on there, so you have any clue if the previous owner did? You ever verified your speed on your speedo with a GPS? Reason I am asking is if you are using mileage to calc. your MPG & your odometer is off due to larger tires & not being re calibrated then your MPG could be way off.
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
ChaseTruck754 wrote:Going off on a tangent here so sorry, but Jesus - did you calibrate your speedo when you did the lift & put bigger tires on? If I remember right you fixed a lift that was on there, so you have any clue if the previous owner did? You ever verified your speed on your speedo with a GPS? Reason I am asking is if you are using mileage to calc. your MPG & your odometer is off due to larger tires & not being re calibrated then your MPG could be way off.
good point chase
THEJESUS
Re: 1989 Build
Post by THEJESUS »
Chase thanks for that I will check that out! didnt mean to barge in on your post here
S00TLYFE
Re: 1989 Build
Post by S00TLYFE »
Goodies arriving for me when I returned home from a week working in Portland
tanneraz21
Bronco Info: 1987 Bronco XLT 5.0
Re: 1989 Build
Post by tanneraz21 »
bassani is 420 friendly? haha
