Front end vibration when front hubs are locked
Ojb
Bronco Info: 95 bronco, 5.8/e4od
Post by Ojb »
I have a vibration in my front end when the hubs are locked and the transfercase is in 2wd it goes away when I shift into 4wd or unlock the hubs. I have completely gone through the entire front end and think the problem may be an axle shaft out of balance or possible the Detroit truetrac that I have up front. Just wanted to see if anyone else has come across this before.
Re: Front end vibration when front hubs are locked
Check the clocking on the crossover U-joint
PaulW wrote:Check the clocking on the crossover U-joint
Ditto.
Yep. If the u-joints are clocked wrong you will get a smooth left right wobble in the steering wheel.
[youtube]https://youtu.be/T4P75ZQvpws[/youtube]
This video helps people understand the pulsation that is created from u-joints.
How do you insure the u joints are in phase on the pass side??
You need to make sure they are parallel. Same as a driveline.
Thx for the info as I have to do this really soon!!
Ojb
Post by Ojb »
They are clocked correctly. I marked them before I took anything apart.
Ojb
Post by Ojb »
How fast are you going when it vibrates?
Ojb
Post by Ojb »
The vibration starts around 25-30 mph. I plan on having both front axle shafts balanced when I have it apart for the coilover swap. I do think it's either the axles or the differential, just wondering if anyone else has come across this before.
Ojb
Post by Ojb »
It's coming a parts this weekend and am hoping to fix the problem while its apart.
It's just weird that it's there when you are in 2wd with hubs locked but it goes away when you are in 4wd with hubs locked. It might very well be a bad u joint or maybe the gears were not set up correctly in the third member.
Ojb
Post by Ojb »
Thanks for the input guys
The driveline could possible cause this...
