The Chief's Clever Bronco
Re: The Chief's Clever 96 Bronco
Tried the grindingbthem flat and whacking with a chisel and my 2.5lb brass hammer. Can't get enough momentum. But, I'm on the last 2 rivets now with drilling and then I'll be able to mount the passender side pivot. I can tell you if both sides were attached via rivets I'd just be going C&T.
Hey guys,
Ive reached the point where I am now torque on the beam drop pivots. I found an install manual on FSB which listed the standard torque specs at 60ft.lbs for 7/16 bolts and 90ft.lbs for the 1/2" bolts that are used. Do these sound correct to you?
I am using blue threadlock on bolts without nylock nuts.
Google a torque spec sheet for grade 8 bolts. Go to images & have a look. You should find multiple references for dry & "wet" (loctite) torque specs. A few years back I did this & then printed & laminated the charts back to back so one side is dry spec & one side is wet spec. I have this in my toolbox somewhere, but as I write this my mind is thinking "hmmm, I haven't seen that in a while, where is it...?" I'll have to go check that out.
Thanks Steve!! If you find that chart post a thread for it!
Looked up the specs. For Grade 8:
1/2-20 plated is 90 ft.lbs
7/16-14 plated is 52 ft.lbs
The chart is something like this (found on google a second ago), and of course I looked for mine a bit after typing that response & it's not in any of the tool boxes. Maybe it's in the crew. That's what I get for not using my tools enough recently!
![Image](http://www.profabricationtechniques.com/wp-content/uploads/2011/02/fastener-torque-charts-1024x750.jpg)
Lol! Bring your tools on over, Steve!! Thanks for the chart!!ChaseTruck754 wrote:The chart is something like this (found on google a second ago), and of course I looked for mine a bit after typing that response & it's not in any of the tool boxes. Maybe it's in the crew. That's what I get for not using my tools enough recently!
Finally made some progress after hours spent lying on my back!
- Rough Country drop pitman installed. Torqued to 175ft.lbs
- 20160119_174626-1024x1820.jpg (297.13 KiB) Viewed 1062 times
- 93Broncobuff
Lookin REEEEEEEEAAALLLL clean all up inside there amigo!
Went to Solo Motorsports today to buy a pair of Bilsteins for the rear suspension but ended up walking out with a complete set!!
Thank you for the kind works, 93broncobuff and cwrisley!
Re: The Chief's Clever Bronco
Was able to get a little bit accomplished today. Took my time reassembling the passenger side, since this was my first attempt. Wish I had made more progress today but I kept having to make runs to Autozone for little things.
Looks great! Score on the front shocks!
Thanks Brian! I wish I had washed and painted the springs and radius arms like I did the beams pivots. I will probably pull the springs and paint them and the radius arms when I install the fenders.
I received one heck of a deal on the entire set of shocks!! Even after working a 16 hour day it was difficult to sleep because of the excitement. I did need to find nuts for the in front of the coil pair originally and then I lost the one on the behind the coil shock. After a failed trip to Home Depot trying to find the correct replacement I purchased a complete set from Autozone. They were an oddball size, M12x1.50. Luckily there are a bunch of vehicles out there with that same size wheel stud. So that's what I used on the top along with some thread lock. They actually made cinchin things up a little easier.
Lookin good, but why o why didn't you clean those springs!!!! Hahahahaha
Ha!!! I figured you'd say that, Tony. I think I am going to use a pressure washer on the springs and radius arms then I'll pull them out and paint them when I put on Princess's skinned fenders.
I originally did all the prep work on the crossmember since I would be drilling fresh holes and wanted to prevent corrosion. I didn't think it would turn out as nice as it did. So now I am really kicking myself for not doing the same to the springs and radius arms. But, if I am lucky that won't really matter because she'll be dirty from the Hammers!!!
It's done!!! Well almost. Still needs an alignment and to throw my 35s back on at Tucker Tire. Bilsteins on 4 corners now!!
What size are the fog cutout Will?
