Loving the look of the rear glass!
hollandermotorsports
Picked up my stand alone harness last night from my buddy that built it. Pretty stoked on it and I will be able to mount inside the cab. Also we went with a 96 brain so we could have OBD2 for tuning and data logging on the fly.
Sweet, good choice!
The new power plant.
What are the specs?
Its a 1996 5.8 roller block with cam, GT-40 heads with some porting, 24lb injectors, 1.6 Ford svo roller rockers, and some other goodies. My buddy that assembled said he believes it should be an easy 400-450hp after dyno tuned.
Nice !
Picked up the C6 I had built and got it loaded up and ready to install. Also managed to put the motor back in and start reassembly of the front end since I took it all apart to paint it. Decided to stick with the blacked out theme on the exterior. Also made the decision after talking to Scott S. to go big with GPS systems and with the support I get from PCI I would be a fool not to so as you see put in a HDS 7 on the drivers side and ordered a HDS 10 for the passenger side. Should not get lost in mexico now. Also PCI only has 4-5 HDS 10 left and then the only option for large GPS is the 12" touch at $3500 roughly so if you want one tell them I sent you and maybe they will give you a break. Interior starts today.
Also did a little tweaking of the dash since the 10" will be a little larger than originally planned.
Did Juan build that harness?
Travisfab wrote:Did Juan build that harness?
Borrego did it for Juan.
Really nice man
A/C!!
PaleRider
Post by PaleRider »
Nice
PaleRider
Post by PaleRider »
Work
Loydski29
Bronco Info: 93 bronco stock for now
Post by Loydski29 »
what headlights are those?
Tony on here made them for me. I ordered and extra set that I will probably not use if you are interested otherwise PM him I forget his name on here but I think it is tcm glx
Truck looks great, and yes I built those headlights ;)
Interior is going in. I have a little over a week to have it done for Off-Road Expo.
